Can you remove AYC and keep ABS working OK?
Old Apr 28, 2018 | 03:41 PM
RSMike's Avatar
Does anyone know if I can remove all the AYC ECU and wiring with the ABS still working fine?
I've changed my Evo 6 to a LSD RS rear end, so I dont need the AYC system anymore.
I'm concerned the ABS system will have a fit if I remove the AYC ECU and wiring.
I know there is wheel speed sensor outputs from the ABS ECU that go to the AYC ECU.
But i'm not sure if there are other things that will affect it.
I'm installing an aftermarket ECU so i'll be using the ABS outputs to get my wheel speeds (4x) into the ECU also.
Evo_AK
16
Sep 28, 2015 12:26 PM
Lion_Sam
May 5, 2015 05:49 AM
RevLimiter
Aug 20, 2012 07:01 PM
Livefast.eu
13
Apr 8, 2012 01:58 PM
ronin_hungary
Jun 17, 2011 10:18 AM
