Evo 9 hard start cold, no start hot
Old May 2, 2018 | 10:11 PM
  #31
2006EvoIXer's Avatar
Originally Posted by BrandonIX
took me 2 days from start to finish, you slackin man! Haha jk
I'm still waiting for my head to be completed. So my slacking doesn't count.
I wish I had friends to help me.
Old May 2, 2018 | 10:22 PM
  #32
BrandonIX's Avatar
Yeah i get it haha Any pics you want of specific areas?
Old May 3, 2018 | 12:15 AM
  #33
intake manifold, throttle body, DV, and fuel lines.
Old May 3, 2018 | 07:19 AM
  #34
BrandonIX's Avatar
Maybe some new plugs might help? Haha, everything else looks good from what i see. And no leaks anywhere. Let me know other pics you need.
Plugs 1 on left, 4 on right. 2 look burnt on the middle and gapping seems tight.
Intake and vaccum lines.
More intake and lines
Fuel lines
3 and 4 injectors
1 and 2 injectors and FPR
More vaccum lines and intake
Under throttle body
Old May 3, 2018 | 07:50 AM
  #35
Left plugs looks like it's running lean. And 1&3 have burn marks on back side?
Old May 3, 2018 | 07:57 AM
  #36
Sorry. Double posted.
Old May 3, 2018 | 07:59 AM
  #37
I couldn't tell where your fpr solenoid hose is connected in your photo. Is it connected to 3-way? And other line goes to boost gauge?
Old May 3, 2018 | 09:17 AM
  #38
Pal215's Avatar
Thanks man, what would cause a leaking injector other than the o rings? I replaced them all a couple days ago. And i will definately try the relay to shut it off! Definately all makes sense though!
If the injector valve itself is leaking, it could be letting the residual fuel through leftover pressure into a cylinder after the car is off. I'm dealing with this right now and the car takes forever to start just as you mentioned. There is a way you can test this without a flow bench...but you have to be very careful as it could get messy. Here's how I did it: ( I don't recommend this if you don't feel comfortable)
You don't need to use Evoscan, just unplug the crank positioning sensor and turn the engine over a few times with your injector ends exposed and injectors unplugged. This will run the fuel pump, but not the injectors. What your interested in testing here is the state of the valves themselves. The O rings on your injector only isolate it from the outside to prevent boost leaks and outside fuel leakage.
Old May 3, 2018 | 09:21 AM
  #39
Biggiesacks's Avatar
NM i see it runs ok.
Old May 3, 2018 | 11:21 AM
  #40
https://youtu.be/p0p9MMm9ARg
​​​​​​If he pulls the fuel pump fuse to shut engine off and then replaces fuse before starting, wouldn't this test for leaky injectors? He can even crank it while fuse is out just to purge any fuel in intake. You are one brave soul playing with fuel. Lol
Old May 3, 2018 | 12:16 PM
  #41
kaj's Avatar
kaj
I have the Injen pipes too
Ditch those ASAP. Thank me later
OP: are there two couplings on the UICP, near the throttle body?
Old May 3, 2018 | 12:58 PM
  #42
what's wrong with Injen pipes? It's working.
Good eye on that extra clamp. Strange.
Old May 3, 2018 | 01:24 PM
  #43
Pal215's Avatar
That would only test it if the injector is really leaky. The gradual leaks would go undetected. Not brave, just crazy enough to try it haha.
Old May 3, 2018 | 01:26 PM
  #44
Pal215's Avatar
The injen pipes have a tapered region that could effect performance. Other brands make pipes that have true 2.5" all the way through the intercooler tract. At least injen has a CARB E.O. # haha
Old May 3, 2018 | 01:46 PM
  #45
That's the licp. It has the small 1.75" pipe and enlarges to 2.5". They have an interesting design where it gradually expands to 2.5" to mate up with intercooler. Most others use straight 2.5" and enlarge in the coupler instead.not sure if there is much power difference.
