Evo 9 hard start cold, no start hot
Hey guys, i just did a a small engine rebuild and am having in issue. I had 2 other buddies help me with the car so I dont know all the grounds and connectors they touched but i believe I checked everything over. The posts i find on research steer me in the right direction but none have my same symptoms.
When the car is cold, it takes about 7-10 cranks to start and sometimes helps when i WOT. When the car is hot or warmed up, it wont even start literally right after shutting it off. I need tp wait a couple of hours for it to be completely cold to start it. Even on a cold start, if I shut it off imediately afterit starts it will not start again. But what it weird is that when it is running, its a raped ape on the streets haha. It pulls, idles, and runs just perfect. So i have no idea.
I have a new Walbro 255 that I havent got to install yet if its fuel pressure related. And I am currently waiting for new injector insolator's from injector to mani. I also have COP i havent installed yet if it is spark related. But i want to find the problem before throwing parts at it and now no one knows the real issue. Before any work was done I never had an issue with the car besides loosing coolant.
New Parts
Headgasket
Timing belt and Balance belt
All timing components
Water pump
Thermostat
Intake Mani Gasket
All exhaust/turbo gaskets
ARP headstuds
AC delete
Any info or tips will help, thanks.
New Parts
Headgasket
Water pump
Thermostat
Intake Mani Gasket
ARP headstuds
AC delete
I put fuel system cleaner in the tank today but i never cleaned them before. I have DoctorInjector close by for a good rebuild price but i dont want to just buy things because im unsure what wrong. Would they really clog up that bad with having the rail off for 2 days? And no fuel pressure gauge right now. Should it hold pressure when the car is off?
I installed the new Walbro yesterday and it did not help. And i guess it already had a Walbro in it from a previous owner haha. But when i pulled off the fuel lines from the pump, none of them had pressure behind it. They more so just dripped a little gas but nothing felt pressureized. Sound normal or am i onto something?
Sounds like you have a leaking injector. When starting your engine, your leaking injector is allowing extra fuel into that cylinder. It will be hard to start until you can flush out enough fuel with fresh air. When hot engine, it gets worse because when you shut off engine, fuel drains into same cylinders until pressure is gone. So when trying to start, it's flooded. But I would assume engine eventually starts.
Try pulling your fuel pump fuse to shut off hot engine. Then put it back to start engine. If problem is still there, then (at least) you can rule that out.
Do you smell fuel when the car won't start? You said the car starts when cold if you hold the throttle open, will it not start if you don't do that? How do the spark plugs look?
