Weir 12-plate for Evo VIII/IX review & info.
I installed the Weir 12 plate a while back on my 9 track car and it was good for a while.
Upon disassembly the driving edges of the plates were pretty beat up.
Sent it off to John at Team Rip for his 12 plate (actually had him give it the full treatment) and 1.5 way. Never looked back.Completely transformed the car and was as good in the 5th season as the Weir was on day one.
Shoe
Shoe
https://m.imgur.com/gallery/MYx68My
someone snapped a pic a couple weekends ago - 8/10 ohlins, tanabe fsb and wl 24mm on fill stiff. rear off the ground
Yep. Every suspension and tire combination I've used = tripod. Even stock, I'd assume. A few non-Evo people I know can't, for the life of them, figure out why we can't/don't/won't tune that out. It makes no sense to them why we would be okay with it.
Looks like late braking into a turn. The transition from one side to the next turn is causing the tripoding of the suspension. Some have had luck tuning it out with a smaller sway rear bar or using adjustable end links. If you run a high enough spring rate in the rear then might as well disconnect the rear sway bar to see if that makes any change.
Malocas
Oct 24, 2013 06:11 PM
aamoedo
Jul 12, 2013 09:58 AM
Jim3142
Jan 16, 2013 10:51 AM
93 3gt vr4
24
Oct 26, 2012 09:05 AM
