Stock engine internals maximum rpm!
Old Jul 1, 2018 | 02:59 AM
Nikoro's Avatar
Hello guys. I am planning to change my stock camshafts on my evo ix with bigger. I am between tomei poncams 270 type R with lift 10.7 and 10.2 and tomei procams 270 with 11.5 lift.I was wondering what is the max rpms over the stock redline that evo ix engine can handle with safety without a failure. And if i need to change connecting rod bolts or connecting rods for better safety. Also if i go with procams its a must to change valve springs and retainers too? Or only valve springs.My engine has stock internals and stock turbo. But i am planning changing the turbo in the future (hks 7460R). Give me your lights guys !!
Old Jul 1, 2018 | 04:41 AM
ctfpevoVIII's Avatar
change your springs and retainers if you want to consistently rev above the stock rev limit, also unless your going to run a larger frame turbo there is no point in revving much higher since the turbo will not be in its efficiency range .
Old Jul 1, 2018 | 08:08 PM
LetsGetThisDone's Avatar
8k is the consistently reliable limit.
Old Jul 1, 2018 | 09:57 PM
kikiturbo's Avatar
7460r will give you max power at 7000 and then keep it flat untill 8000... we run one such stock block engine with gsc s2 cams and 7460 with 8200 rpm rev limit.. However, "doing it with safety without failure" is relative..
Old Jul 3, 2018 | 04:46 PM
Dakota Evo's Avatar
I ran even an FP Red and at over 7800 rpm on a 2.0 it was out of steam
green hta71 7640 ef1 ef2 7200 rpm is fine
red gtx30 ef3 7500
black ef4 25g 7800
LVSBB6
19
Apr 16, 2023 11:56 AM
Mohamed _salama
Nov 6, 2012 10:14 AM
marck_c
23
May 1, 2008 12:50 PM
NITROHEAD
Lancer Aftermarket Forced Induction Tech
26
Feb 6, 2008 09:51 AM
quantum
Sep 9, 2004 04:22 PM
