Engine Knocking
Old Apr 10, 2004 | 06:21 PM
evolushen's Avatar
Engine Knocking
Ok, first off I had the EMS installed yesterday. Today while driving, when I switched into 2nd I heard a noise and then a 'knocking' sound. Now it is always there and doesn't go away. With the higher the RPM, the faster the noise gets. I am assuming that it's a piston. So I brought it to a mechanic that worked on race cars and he said just by listening to it that the rod is shot. He asked me if I heard a noise and I said yes, he said that it detonated and I would have to get a new bottom end which would prob be about 4,000 depending on how expensive Mitsubishi is. Does this sound right to you? Thanks.
Old Apr 10, 2004 | 06:27 PM
evo542's Avatar
no it doesn't there are couple of evo's in 500whp area with the stock block and no problems
Old Apr 10, 2004 | 06:33 PM
hotrod2448's Avatar
It sounds reasonable if the engine was detonating. You should take it to a good local mechanic and get a second opinion.Judging by the fact that you have an EMS I would say you don't care about a warranty, If you do need a new bottom end you should get a stroker kit. It's probably close to the Mits. would charge you for parts.
Old Apr 10, 2004 | 06:35 PM
hotrod2448's Avatar
Was the noise a really loud "ping" and then the knocking?
Old Apr 10, 2004 | 07:02 PM
evolushen's Avatar
No it sounded more like a pop or something. Thanks guys for the opinions. What's the best stoker kit to get? Might as well just do that right?
Old Apr 10, 2004 | 09:23 PM
prowler's Avatar
Well, I presume you are running good gas? If not try to get some 94, or 93 and put in a gallon of Xylene.
But then again, I would think the ECU would compensate for bad fuel and pull timing. So heck, idunno.
Old Apr 10, 2004 | 09:25 PM
evolushen's Avatar
I am running Sunoco Ultra 94
Old Apr 11, 2004 | 09:19 AM
prowler's Avatar
Well then, you have a wee bit of a predicament. Sorry to hear that.
Keep us updated on the problem/fix. Good luck
Old Apr 11, 2004 | 10:14 AM
hotrod2448's Avatar
Toda makes a good kit from what I have heard. I also believe Jun and Tomei make quality kits as well. I would definately get a second opinion first and maybe have someone drop the oil pan and give it a good look.
Old Apr 12, 2004 | 07:51 PM
evolushen's Avatar
Thanks guys for all your input. It turns out it was the rod bearing I will wait now and see what has to say about it. Good luck on that one right?
Old Apr 12, 2004 | 08:06 PM
Mister2zx3's Avatar
Who tuned the EMS? and why is Mitsu involved with an aftermarket ECU in use?
Old Apr 13, 2004 | 10:11 AM
evolution9's Avatar
make mitsubishi replace the engine. the 4g63 is notorious for destroying rod bearings! mitsubishi installed a new block in my car. two months later (no mods) the rod bearing was shot. my guess is it was a factory defect and not something you did to the engine.
