What am I missing on my transmission?
Old Feb 4, 2019 | 02:41 AM
BigBurd95's Avatar
Yesterday I noticed on my Evo 9’s transmission (six speed) an opening that I’ve never noticed it being open or unplugged? This must’ve happened recently since I’m sure I would’ve noticed sooner, I’ve tried googling and doing research but cannot find anything maybe I’m not looking in the right place idk but I need help find out what’s suppose to be there or if it’s suppose to be open like that which I doubt, any help would be very appreciated! I’m learning as I go so excuse my ignorance
Old Feb 4, 2019 | 04:23 AM
Kevin Troy's Avatar
reverse sensor/switch??
Old Feb 4, 2019 | 05:14 AM
staywide8's Avatar
There should be a pressed in cover there-covers the clutch fork pivot install area.
Old Feb 4, 2019 | 11:42 AM
butte's Avatar
Yeah what staywide8 said, there's a little rubber ventilated cap that sits in that
Old Feb 4, 2019 | 12:33 PM
BigBurd95's Avatar
I believe I’ve found the part you guys were talking about, if this is the incorrect ventilation cap please lmk
https://stmtuned.com/collections/mit...ole-vent-cover
Old Feb 4, 2019 | 12:45 PM
LetsGetThisDone's Avatar
No the end of the world if that's left open as is. It's just a vent hole for the clutch/bell housing. Theres no fluid in there.
Old Feb 4, 2019 | 01:38 PM
heel2toe's Avatar
I believe ^ is correct. Unless the 6 speed is different there on the 5 speed its a lil freeze plug cap thingy that pops out to gain access to the shift fork.
https://stmtuned.com/collections/mit...-case-seal-cap
Old Feb 4, 2019 | 08:06 PM
barneyb's Avatar
The six speed may be different but on the 5 speed, at clutch time, you punch the frost plug looking thing into the interior of the bell housing. There's a little bolt inside the bell housing that locks the throw-out arm shaft in place. Remove the bolt and slide the shaft up and out that hole. Then the throw-out arm may be removed. In other words, the hole is there so the shaft can be removed. The frost plug is a dust cover. Since clutches make dust - not sure if the frost plug thingy keeps dust in or out.
Old Feb 4, 2019 | 10:47 PM
kaj's Avatar
kaj
It may the spot where the clutch fork pivot rod thingy comes out. If so, it's missing a "freeze plug" like everyone is mentioning. Cheap to replace, if you want. I'd get a something from a hardware store and be done with it.
Old Feb 5, 2019 | 03:16 AM
kikiturbo's Avatar
yeah, clutch pivot rod plug, as stated above... I just had a look..
