Rods & Pistons
Old Feb 24, 2019 | 08:21 PM
steven121's Avatar
Rods & Pistons
been researching alot of threads but it seems everyone is going stroker or 4g64 block
so here is the goal, will be a daily driver/weekend car whenever the sun is out I don’t drive it in the rain
GOAL on a 2.0L block
700hp on e85 with a GTX3582R dual ball bearing, head is a stage 1 map with 270 cams. Going .20 over with 9:5:1 compression
What combo set should I get for realibility?
going I beams for sure
build will be done in about 2-3 weeks once i pull the motor wednesday
Old Feb 25, 2019 | 10:33 AM
LetsGetThisDone's Avatar
The MAP stage 1 is just a basic cylinder head refresh, hot tank, valve job, and deck surface. You should have the head done by someone who knows how to do cylinder heads (and engine work in general) correctly, IE HeadGames, 4Piston, or Curt Brown. Idk what "270" cams mean but I would probably upgrade those to one of GSC's offerings, S3's or R2's depending on what you end up doing with the bottom end and high you plan to rev it.
I wouldn't build a 2.0L, kind of not the greatest for a bigger turbo street car. Build a 94mm stroker 2.2L. They make more torque, light the turbo sooner, and just drive better. English Racing can you set up with the correct rods, crank, and piston combination. You can do 150 or 153mm Carillo rods, their custom spec Wiseco HD pistons, and an eagle forged crank.
Old Feb 25, 2019 | 11:26 AM
steven121's Avatar
I have the 270 tomei cams, I have a guy who can port the head no problem
just trying to figure out a good setup to get ready for the build
Old Apr 9, 2021 | 03:18 AM
AlexEvo26's Avatar
Sorry, wrong thread ...
420a-t
26
Feb 22, 2017 11:49 PM
triple L
Dec 20, 2013 08:44 PM
djdino
Dec 15, 2013 11:14 AM
Evo8Emperor
21
Nov 24, 2009 03:42 AM
slowTsi
Automotosports - Illinois
Aug 5, 2005 03:49 PM
