New fuel pump setup
Old Dec 24, 2019 | 08:30 AM
Yamahar1's Avatar
New fuel pump setup
Finally got around to building my triple walbro hellcat 525 setup
Old Dec 24, 2019 | 11:55 AM
miragevo's Avatar
Veteran: Navy
That looks insane!!! How much power you planning on making?
Old Dec 24, 2019 | 04:52 PM
hutch959's Avatar
i wouldnt think there is any way that siphon system is going to work with that much flow.
maybe im wrong.
looks good tho.
Old Dec 25, 2019 | 07:01 AM
miragevo's Avatar
Veteran: Navy
This might help....This is from Radium...
One major issue with the OEM EVO 8-9 fuel pump hanger is the restrictive return port and venturi jet pump. When using aftermarket high-flow fuel pumps, the OEM jet pump becomes too restrictive creating unwanted back pressure in the regulator return line causing excessive fuel rail pressure. The Radium fuel pump hanger includes a venturi jet pump with a new integrated pressure-relief valve to minimize back pressure. All returning fuel from the pressure regulator and crossover hose exit the jet pump keeping the OEM gas tank baffle full for starvation protection.
http://www.radiumauto.com/Fuel-Pump-...8-9-P1265.aspx
Old Dec 25, 2019 | 09:05 AM
Yamahar1's Avatar
I will be trying the radium ventiri jet pump kit. I just installed the stock one for looks.
Old Dec 25, 2019 | 10:23 AM
LetsGetThisDone's Avatar
I guess I just don't see the point of this. Seems way harder to work on then building a surge tank and using actual big pumps like AEM 400LPH 044's..
And/or running a mechanical pump since a double pump Walbro 525 setup will make 1000whp on E85.
Also, that stock return Venturi will not flow enough. You should consider revising that with what radium offers.
Old Dec 26, 2019 | 08:16 AM
RazorLab's Avatar
Why on earth do you need three 525's???
I'm also with letsgetthisdone. Highly recommend getting the radium venturi.
nickracer9
Jun 17, 2021 01:28 AM
1UpMoto
Apr 19, 2017 09:06 AM
evoforlife
35
Apr 4, 2013 10:38 AM
norcalSRTrida
50
Oct 15, 2010 08:12 AM
Lucas English
Aug 8, 2007 09:26 PM
