FP 54 green bb
Old Jan 6, 2020 | 12:41 PM
jairobm89's Avatar
5 Year Member
FP 54 green bb
Hi guys I wanted to know how much whp I can have with that that turbo for my evo 7, the car when I bought it came with a fp black bb with 7 years on, they have told me that it is the old version that has, but for my daily use I did not like the spool and I want to buy the fp 54 green mhi w/18 psi actuator I only want 450-500 whp
with 93 and boost juice water methanol injection
and sometimes vp 100 with boost juice
no e85 in my country
sea level altitude dominican republic
I have this in the car right now:
2.0l built motor
Wiseco pistons 8:8:1 and manley rods
Brian crower dual valve springs retainer titanium
Stock crankshaft
Hks cams new generation 274intake/278ex
Fuel rail aem
Aem 340 lph fuel pump
Fic 1000cc
Down pipe megan racing
Exhaust hks
O2 housing jmf ported
Halltech elite 1000 ecu
Fp black bb with fp wastage 18 psi
Carbonetic triple carbon clutch
Aem water methanol injection vs2
Jdc coil on plug
Ams intercooler
Map performance oil cooler
Hks oil cooler thermostat
Intake fp
Tial q bov
Fp manifold ported
Intake manifold ported
Old Jan 6, 2020 | 01:09 PM
LetsGetThisDone's Avatar
It should do 450-500 with pump gas + meth. It's a 400-425whp turbo on pump gas. So it kinda depends on how much meth you spray. But I would think 450 would be easy. Especially with 93 octane gas.
Old Jan 6, 2020 | 01:46 PM
Dallas J's Avatar
Veteran: Army
Agreed with what Sean said. Would also caution against getting the SS housing, look up Abacus's results switching to it from an MHI housing and how much spool he lost.
Old Jan 6, 2020 | 01:49 PM
jairobm89's Avatar
5 Year Member
thanks and taking note about how much spray
Old Jan 6, 2020 | 01:50 PM
jairobm89's Avatar
5 Year Member
thanks It would be mhi 18 psi actuator
Old Jan 6, 2020 | 02:10 PM
Dallas J's Avatar
Veteran: Army
That should be a good all around turbo. Pretty similar to my Blouch 1.0XTR in flow and size.
Old Jan 6, 2020 | 03:19 PM
ctfpevoVIII's Avatar
You should hit your goal, I run a BBk-3b which is basically a Blouch 2.0 xtr (57 lb/min) . I don’t have access to e85 or I would run it ,but I run 93/ meth and have made 488/409 @ 30 psi on a mustang dyno. My car is running built 2.3 with all supporting mods and recently swapped my GSC S3’s for some R2’s which benefit stroker motors. Good luck man!!
sokaroza
69
Jan 11, 2012 03:39 PM
Mikey@Spec-Ops
92
Dec 12, 2011 09:47 PM
e4on2e5
May 26, 2011 08:25 PM
Piro Fyre
21
May 20, 2011 03:23 AM
ForcedPerformance
May 4, 2010 04:29 PM
