JMF mainfold
Old Jan 15, 2020 | 09:42 AM
Usman Ali's Avatar
JMF mainfold
hello,
i just considering ordering a foward facing T4 twin scroll mainfold from JMF but i can not find any picture of it on an evo any where, if any one has a JMF FF mainfold twin scroll mainfold please post here .
also does a k&n 4" part number 2510 short air filter fit with this FF maindold?
thanks.
Old Jan 17, 2020 | 09:26 AM
Usman Ali's Avatar
no one??
Old Jan 17, 2020 | 05:41 PM
Speedlimit's Avatar
Admin Emeritus
Hi,
I just moved your post to the Evo Engine/Turbo/Drivetrain forum. I think you will have a better chance of finding an answer. Good luck!
Bob
Old Jan 18, 2020 | 11:39 AM
Usman Ali's Avatar
Originally Posted by Speedlimit
Hi,
Bob
thanks but I guess no one has any info ☹️
Old Jan 18, 2020 | 10:29 PM
Usman Ali's Avatar
bump ..some please !
Old Jan 19, 2020 | 11:09 AM
LetsGetThisDone's Avatar
I'd email JMF with your questions. They're extremely helpful.
Old Jan 20, 2020 | 10:04 AM
Usman Ali's Avatar
already done that but they said : we do not have any pictures available of the FF Div T4 manifold on a customers car. We only have the pictures that are on the website.
so they don't any pictures on a car...and im just searching Evey where for anyone who has the FF mainfold done by JMF.
Old Jan 20, 2020 | 08:17 PM
I'm not sure why pictures are so important, it's a manifold...
They could probably answer your question about fitting an air filter.
Old Jan 21, 2020 | 12:48 PM
justboosted02's Avatar
For anyone interested...
Seems like the wastegate priority of the left gate may not be optimal? Has anyone actually run this setup? any boost creep issues?
Old Jan 21, 2020 | 01:27 PM
If you're worried about boost creep you probably don't need a forward facing turbo kit.
It's on the collector the same way any other twin scroll manifold is. It just has a tube to move it away from the core support. No manifold for these cars really has great wastegate priority due to packaging.
Old Jan 21, 2020 | 03:40 PM
most manifolds have the wastegates much closer to the actual merge collector. this is more like an additional runner....
proper wastegate priority via CBRD's car
Sheepy has a twinscroll FF manifold with much closer gates to the collector
Old Jan 21, 2020 | 05:22 PM
The distance of the gate from the runner is of little importance. As long as the gas enters the tube to the gate well, it's fine.
Old Jan 21, 2020 | 05:29 PM
The distance of the GSR from the runner is of little importance. As long as the gas enters the tube to the gate well, it's fine.
Im sure it works, jmf looks like it makes good stuff, it just seems less than ideal. If someone wanted to make a wastegate pressure only map they may have trouble with this setup is all im saying, and im wondering if anyone has actually run this manifold
<----- Has run a t4 twinscroll turbo setup (full race)
Old Jan 21, 2020 | 05:31 PM
I've yet to run any twin gate manifold on these cars that run wastegate pressure. ETS, Full Race, Sheepy. All of them make more boost than spring pressure. So you have to spring about 3-7psi lower than target wastegast boost depending on the turbo.
So, I'm not sure what your point is here.
Old Jan 21, 2020 | 05:41 PM
wastegate pressure via rated spring is somewhat relative, the problem with a manifold with a poor wastegate priority is boost creep as the flow in the waste gate path cant keep up due to the momentum/velocity of the gas unable to make the abrupt turn in the flow path and therefore more and more gas going through the turbine.
my full race setup did not creep. wastegate pressure was 20PSI
just trying to start a discussion in a dead-ish forum
