Oil leak on top of coil
Old Feb 12, 2020 | 04:34 PM
JR Sunhel's Avatar
This is a strange, and probably on the noob side. I've tried to identify this leak including new valve cover gasket and spark plug gaskets, but it's still here and soaking the first spark plug well. The others are bone dry. Any idea what this might be? It's enough to start dripping on the sides of the valve cover..
Old Feb 12, 2020 | 04:44 PM
hutch959's Avatar
is the valve cover cracked?
Old Feb 12, 2020 | 04:53 PM
JR Sunhel's Avatar
I didn't see one when inspecting it..
Old Feb 12, 2020 | 05:20 PM
LetsGetThisDone's Avatar
Is that little drain tube leaking?
Old Feb 12, 2020 | 09:17 PM
JR Sunhel's Avatar
That little tiny port? Can that leak?
Old Feb 12, 2020 | 11:29 PM
Yeah, it's a drain turn so water doesn't collect in the valve cover, god through to the other side. They sometimes start leaking oil.
Old Feb 13, 2020 | 10:23 AM
JR Sunhel's Avatar
There is only coming from it, it's dripping on to the intake manifold. But I don't think it's the cause, it's more draining the oil that's getting in the valve cover.
Old Feb 13, 2020 | 04:01 PM
gsrboi80's Avatar
It’s probably that the Valve Cover is cracked down inside the spark plug hole/tube. Had the same thing happened and had to purchase a brand new factory Valve Cover, only used ones I found were Powder Coated and wasn’t taking the chance that they’ve been blasted leaving any material in the baffles or could be cracked themselves.
I bit the bullet and just bought a new one.
Old Feb 13, 2020 | 05:37 PM
JR Sunhel's Avatar
You're probably right, it has to be cracked. What a drag.. I'll look into options. Definitely not going for powder coated now that you've enlightened me!
Old Feb 14, 2020 | 05:39 PM
barneyb's Avatar
Maybe the oil filler cap is leaking. A new gasket costs next to nothing.
Mcoffeyevo8
Feb 7, 2020 06:49 PM
RyanD3
Mar 8, 2016 02:37 PM
Jingming88
Oct 10, 2011 02:21 PM
sdfontanini
31
Dec 15, 2008 11:43 AM
Monkey
Jul 6, 2005 06:55 PM
