6-Speed transmission rebuild
Old Feb 26, 2020 | 12:12 AM
Swedevo's Avatar
Unhappy 6-Speed transmission rebuild
Hey guys! I have rebuilt my 6 speed trans and now I am putting it back together again.
I have a problem with getting the output shaft rear bearing in position in the case. There is a snap ring to lock the shaft in position but when it's out the shaft slips down. I can't get it up enough for the snap ring to lock in position..
Does anyone have any experience in doing this? I can't find any info about the 6-speed...
Help is needed!!
Thanks!
Old Feb 26, 2020 | 01:58 PM
kikiturbo's Avatar
as I answered in the other thread.. you shift it into gear with some force.. that will push the shafft up..
do you need the rebuild manual?
Old Feb 26, 2020 | 10:24 PM
Swedevo's Avatar
I have tried putting it in 2nd but the shaft isnt moving at all.. Will try 4th today. I have the manual from Evoscan if that is the manual you mean? In the manual it says it should be put in 2nd
Old Feb 27, 2020 | 03:06 AM
kikiturbo's Avatar
Yeah, dont remember anymore... even though I did one box a few months ago... just bang it into gear untill it lifts.. Keeping the circlip open at the same time helps..
One more thing.. if it doesnt seat right, it will block the whole box..
Old Feb 27, 2020 | 03:36 AM
Swedevo's Avatar
Okey thanks for the tip! Will try today. What do you mean ''doesnt seat right''? The case?
Old Feb 27, 2020 | 06:54 AM
kikiturbo's Avatar
no, if you do not clip it in, the shaft will be too low and you will get some gears clashing on the bottom.. as a result the box will be blocked when you tighten the casing..
cschubert444
Jan 24, 2019 02:53 PM
EVOEvolved
10
Sep 1, 2016 10:12 AM
mci2727
Lancer Tranny/Drivetrain Tech
24
Feb 12, 2016 11:11 AM
nytalonTSi
Jun 16, 2011 03:21 PM
