What fittings are needed for a full fuel system
Old Jul 26, 2020 | 11:24 PM
raverthug's Avatar
Im building a full fuel system. It will be bullet proof fuel hat>Filter>Rail>FPR>Tank Im having trouble finding a list of what fitting would be needed to build this, Can anyone help with this?
Old Jul 27, 2020 | 05:12 PM
hutch959's Avatar
-8 feed?
-6 return?
if so.. just count them all up...
Old Jul 27, 2020 | 09:44 PM
raverthug's Avatar
Yes -8 feed and -6 return. I was wondering if someone had a list since i dont know how many 45s vs 90s ect. Figured it was worth a try before i just dig in
Old Jul 28, 2020 | 06:59 AM
LetsGetThisDone's Avatar
Its a custom fabricated setup, the number of fittings you need will depend on how you build it. I suggest installing/mounting everything on the car where you want it to be/where it will be. Then just look at it and maybe lay some hose between the components and see what you're going to need.
Old Jul 28, 2020 | 08:12 AM
raverthug's Avatar
Ok thank you
Old Jul 28, 2020 | 08:53 AM
Biggiesacks's Avatar
I'm all for the DIY but why don't you just buy BPR's plumbing kit? You aren't going to save any money doing it yourself and chances are it might be more expensive if you make any mistakes.
If your doing it for fun/to learn then I understand that motivation so I would just recommend doing a lot of research into the type of fuel line you are going to use and then choose the fittings that are meant to work with that line. Fittings are meant to work with specific lines and I've seen people screw up and try and mix and match stuff and waste a bunch of money learning that lesson. One tip I can offer is you can look at the fittings that come with the BPR kit and just mirror that.
Old Jul 28, 2020 | 05:30 PM
hutch959's Avatar
i dont see that the bpr kit has a regulator... have to have all the fittings for that too.
ive done a few setups.. and i do what letsgetthisdone suggested.
just look everything over, and start making an inventory of what you need.
Old Jul 28, 2020 | 05:48 PM
Good point. They don't specify what their fuel line kit is setup for so I guess you would have to contact them to find out. I would imagine your still probably on the hook for the rail to regulator plumbing though.
Old Jul 29, 2020 | 09:27 AM
raverthug's Avatar
Thank you for all the input. Im gonna reach out and see if i can have map or bpr make me one how i need. Part of the reason i was going to build it myself is so i can have the fittings anodized a specific color
Alex1743
May 5, 2018 11:50 AM
bluedemon199
10
Mar 30, 2013 12:17 PM
precisionpsi9
Jan 30, 2009 07:32 PM
jdizzy
Apr 11, 2006 05:38 AM
gt40
Mar 15, 2004 08:03 PM
