Which 100mm crank ?
Old Apr 16, 2021 | 03:09 AM
VeebeeIX's Avatar
Which 100mm crank ?
Engine has bearing failure and car is on the way to the shop to be opened.
Previous owner has motor stroked to 2.3 with OEM 4g64 crank on Wiseco Stroker pistons and H Beam rods and car made a comfortable 670whp with AMS 850 turbo kit.
All of this was done over 10 years back and I think I should have everything re done while the engine is out.
With soo many options available, I need some advice on which would be better.
I was thinking of
Eagle 100mm forged crank
Wiseco HD1400 stroker pistons
150mm rods - Manley H Tuff or Turbo tuff I beam , any need going I beam if power wont be more than 650-700whp ?
My plan at a later stage is to change the turbo to a GTX3582 gen 2, but for now want to engine to be strong enough.
Old Apr 16, 2021 | 01:01 PM
LetsGetThisDone's Avatar
Should do a 94mm crank. 100mm is less than ideal in the 4g63 block.
Eagle when they're back in stock, or K1 billet. And look and a Garrett G35-900 instead of the 3582.
Old Apr 16, 2021 | 04:19 PM
hutch959's Avatar
that eagle forged hard to beat for the money
Old Apr 17, 2021 | 02:48 AM
VeebeeIX's Avatar
What rod length would I need on the 94mm crank , 156mm ?
i did think about changing to 2.2L. Seems to be best of both worlds with this.
From what I have been reading it seems the 2.3 seems to have more issues with bearing failure.
Really looking for more reliability, want to car to be able to drive daily without issues.
Other things to look at it would be bigger oil pan and pick up and then looking at the kiggly HLA regulator.
Turbo change will be in a few months, I will run the 850 kit for now until I have more money.
Old Apr 17, 2021 | 10:00 AM
Lumpy Sticks's Avatar
5 Year Member
I have a complete Manley stroker kit for sale if you are interested. 94mm billet crank, h tuff rods with 625 bolts and the HD pistons. All brand new.
Old Apr 17, 2021 | 11:49 AM
EVOFans's Avatar
You can run 150MM or 153MM rod with 94MM crankshaft, just that the piston will be different
153MM give you slightly better rod ratio
Old Apr 17, 2021 | 05:03 PM
justboosted02's Avatar
if you use a 153mm rod then you can use the same piston as the CD will be the same dimension, however the compression ratio is going to drop ~0.5
Old Apr 21, 2021 | 12:17 PM
alpinaturbo's Avatar
What is CD? Compression Distance?
Are you suggesting he can use 153mm rod with currently used 2.3 100mm piston, and 94mm crank, but will have 0.5 lower compression ration?
I never thought you could use 2.3 pistons with 94mm crank and 153mm rods.
Old Apr 21, 2021 | 04:08 PM
Yes.
Yes.
And yes you can.
Old Apr 21, 2021 | 09:12 PM
VeebeeIX's Avatar
Not many of the big brands seem to make 153mm rods ?
anyone have a direct link to any of the online shops.
thanks.
My engine is being stripped down this week, so will need to order parts soon as I know whats wrong.
Old Apr 22, 2021 | 09:41 AM
Construct's Avatar
thanks.
Call up English Racing: https://englishracing.net/pages/contact-us
Old Apr 22, 2021 | 03:27 PM
thanks.
Oliver rods makes an OTS option. I just installed them!
https://oliverracingparts.com/catalog/mt6024lt4-g2/
Old Jun 2, 2021 | 03:30 AM
VeebeeIX's Avatar
Anyone using BW / Bridgeway Billet cranks ? What are your thoughts ?
Looking at purchasing a Ross Sport 2.2L kit and they supply BW billet crank with Oliver 153mm rods and Wiseco HD Pistons.
2.3stroker
Dec 3, 2014 08:45 AM
STi*guy.kiev
16
Jul 14, 2013 09:13 PM
xmel012
11
Dec 29, 2012 09:00 AM
KGB_KGB
Jul 1, 2012 06:12 AM
2k4EvoVIII
12
Sep 9, 2004 08:52 PM
