Does a VTA BOV stay open on decel?
Old Jul 14, 2021 | 09:39 AM
EVO8LTW's Avatar
Since you typically pick a BOV spring to just barely keep the BOV closed at idle vacuum, then it seems logical that the BOV would be open when vacuum is higher than idle — such as coasting in gear. Under these conditions, where vacuum is a lot higher than idle, wouldn’t a VTA BOV pull unfiltered air into the engine?
Old Jul 15, 2021 | 05:52 AM
240Z TwinTurbo's Avatar
Yes, the BOV can open during decel while the throttle body is closed.
Old Jul 15, 2021 | 06:14 AM
EVO8LTW's Avatar
My car pulls about -8 psi vacuum at idle but significantly more at light throttle cruise. If I have a light BOV spring in something like a Tial Q, like an 8psi white spring, the valve is going to be cracked open during steady state cruise (when the throttle body isn't full closed) and ingest unfiltered air. Isn't this a problem for a VTA BOV on a street car? I'm thinking of getting the recirc model (QR) and putting a filter on it instead. Dumb idea?
Old Jul 15, 2021 | 06:42 AM
Abacus's Avatar
I think you are over thinking it. Its not a logging truck spending its time in a dusty environment.
Personally, if its making less then 530whp ,A stock crushed bov works really well under all conditions.
Old Jul 15, 2021 | 06:51 AM
211Ratsbud's Avatar
The charge piping is either ambient pressure or above. I have two quick YouTube videos I displayed some of these situations. A greddy type s with single spring was my weapon of choice. Note the collapse of the bag is momentarily and pre tb reference ports are boost all the time no vacuum.
Old Jul 16, 2021 | 09:56 AM
211ratsbud hit the nail on the head and backed it up with video. It makes more sense when you understand that the turbo is always spinning and blowing air into the charge pipe.
Old Jul 16, 2021 | 10:15 AM
EVO8LTW's Avatar
I agree. He convinced me. Tial Q ordered!
Old Jul 16, 2021 | 04:37 PM
211Ratsbud's Avatar
Take your time with the Tial. They can vent massive quantities of air but can be a little extra work to find the right spring to make driving perfect. I've always set my blow off valves to be open at idle and either open or light on the seat at cruise. This gives predictable part throttle behavior. ( very related to part throttle characteristics of your engine and turbo)
Old Jul 24, 2021 | 10:03 AM
EVO8LTW's Avatar
I got the flange changed in my upper pipe and installed the Tial Q. Works fantastic. Very happy with it. I used the 6 psi spring. It stays closed at idle even with the light spring.
Old Jul 26, 2021 | 03:57 PM
211Ratsbud's Avatar
nice install 👍.
luvboost
Jan 2, 2013 06:02 PM
00EvoX
Evo X How Tos / Installations
Sep 3, 2010 12:52 PM
bigbadbob2k2
May 9, 2006 03:21 AM
TaiwanEvo
Jul 15, 2003 10:43 AM
