from 3.5 inch exhaust to 3 inch
Old Sep 17, 2022 | 06:39 AM
Wheelspk's Avatar
hello,
my evo 8 is tuned on 3.5inch exhust which was custom made but I really heavy 28kgs
mods are fully built engine, built head with s2 cams, fp red ss on 33 psi of boost making 625whp on mustang dyno with e85... ecu is link g4+
my down pipe is 3 inch mated to a 3.5 inch pipe using a reducer and then to a kakimoto muffler.
question is if i go too a total 3 inch titinum exhust instead of my 3.5inch exhust will that effect my tune/afr or boost?
thanks
Old Sep 17, 2022 | 09:47 AM
Wheelspk's Avatar
no one? 😬
Old Sep 17, 2022 | 10:11 AM
Oh, absolutely will affect the tune IMO. May not be a huge issue, but for sure the change in pipe diameter will affect engine exhaust flow
Should have a brush up tune to make sure
Old Sep 17, 2022 | 11:47 AM
Wheelspk's Avatar
damit i was afraid of that... oh well ill keep saving up for a titinum 3.5 inch exhaust and replace my heavy ss exhaust.
Old Sep 17, 2022 | 11:49 AM
Hey, dont make the decision just based on my comment. Let me get my lead guy to comment @Biggiesacks
Old Sep 17, 2022 | 12:32 PM
Biggiesacks's Avatar
I think it's safe to set your expectation that any significant change to the exhaust will require some kind of work on the tune to maximize the setup.
These things are pretty sensitive to exhaust, AFR and WGDC are usually effected.
Old Sep 18, 2022 | 12:21 AM
Wheelspk's Avatar
understood but will it also make a difference if i go different brand of exhust or metrial same size?
Old Sep 18, 2022 | 07:58 AM
The geometry of the exhaust comes in to play too.
I don't have experience with this, but I wouldn't be surprised if material properties also factored in. The better the material can absorb and shed heat the better for the turbo.
Old Sep 18, 2022 | 08:33 AM
^^^Well said
An experienced tuner probably knows what the percentage difference is allowed w/ intake & exhaust flow that will not negatively affect the tune.
As an example, maybe +/-3% (or some value) maybe allowed w/out drastically affecting AFR's & such?
Anyway, after all these years, I think we know that any change in intake or exhaust affects the tune
Wheelspk
15
Mar 23, 2025 12:47 PM
Jetfixrguy
41
Jul 30, 2013 04:18 AM
evojoeinwi
Sep 9, 2012 07:20 PM
JohnBradley
16
Feb 22, 2011 01:35 PM
Stone Cold
Feb 10, 2006 03:36 PM
