Any tips for removing midpipe to stock cat bolts?
Old Oct 16, 2022 | 04:26 PM
Kreeker's Avatar
My exhaust gasket is shot so I'm trying to remove the midpipe to cat bolts, but having no luck... I'm trying to use a M12 stubby impact which has 250 ft/lbs of torque, so it might not be enough...
I've never used a torch, but my thought was to get a MAPP torch and heat up the bolt on the cat side and try to have the nut and bolt came out as one piece. Would this even work? Or should I heat up the nut on the midpipe side to get the nut off and then remove the bolt some other way?
Do I need to worry about the torch with my Greddy Ti? Years ago I saw someone selling a Greddy Ti with a cracked flange with the claim that an exhaust shop used a torch on it and it broke off...
Old Oct 16, 2022 | 05:22 PM
Jaraxle's Avatar
Hit it with PB blaster every 2 hours for 24 hours. Try impact. If failure then torch it. Try impact. Failure again... time to cut.
I got so sick of all this, I replaced the four bolts for the CAT with TITANIUM hardware. Copper anti-seize wasn't doing the trick for me after a winter or two.
Old Oct 16, 2022 | 06:29 PM
Yeah, no doubt the undercarriage has seen the wet weather. My first thought was time to cut those fasteners as you noted!
Old Oct 16, 2022 | 06:41 PM
Kreeker's Avatar
What’s the best way to cut it?
I have a hackzall with a 5 inch metal blade, but there is no way for me to rest the shoe on anything, so it seems too dangerous…
After I cut the bolt, how do I remove the bolt from the cat side? Can it just be hammered out or would it need to be drilled?
Old Oct 16, 2022 | 07:14 PM
Jaraxle's Avatar
THIS will do it
Old Oct 16, 2022 | 07:15 PM
Jaraxle's Avatar
WEAR SAFEY GLASSES !!!!!
I had one of these wheels EXPODE once and it hit my safety glasses... I would be OL'ONE EYE if wasn't wearing them..
Old Oct 16, 2022 | 07:42 PM
Biggiesacks's Avatar
I dunno about cutting the studs out of the cat. Properly replacing them could be a huge PITA.
You try hitting it with penetrating oil? Sometimes when things are stuck, tightening it just a tiny bit can help break it free.
If that fails, bring the heat.
EDIT:
I see they are caked in rust. Some naval jelly or other rust dissolver will probably be really helpful.
Old Oct 16, 2022 | 07:55 PM
^^^Good point. Kinda forgot the CAT has a permanent, pressed stud vs nut & bolt?
Old Oct 17, 2022 | 07:36 PM
ViciousLSD's Avatar
Nut breaker/splitter, but there seem to be room to hammer a wrench there
https://www.walmart.com/ip/Heavy-Duty-Nuts-Splitter-Tools-Set-Nut-Breaker-Tool-Durable-Portable-Heavy-Duty-Nuts-Splitter-Tools-Heavy-Duty-Nuts-durable-01/1745272403?wmlspartner=wlpa&selectedSellerId=10117 8708&&adid=22222222227000000000&wl0=&wl1=g&wl2=c&w l3=42423897272&wl4=aud-393207457166la-51320962143&wl5=9027656&wl6=&wl7=&wl8=&wl9=pla&wl1 0=571399075&wl11=online&wl12=1745272403&veh=sem&gc lid=CjwKCAjw-rOaBhA9EiwAUkLV4s21DkM4RM4T4QoX8XTPZfLYMhDvhG5g7n5 8IR-V77xb6VoI127zQBoCcEwQAvD_BwE&gclsrc=aw.ds
Old Oct 17, 2022 | 07:56 PM
DontStopMe's Avatar
its a more expensive tool, but a magnetic heat induction gun is a great tool to add to a collection. I have a bolt buster, it works amazing whenever you can get to an area on the nut/thread side.
Old Oct 18, 2022 | 01:36 PM
bcollins92's Avatar
I sell the induction heating tools if you want one lol, but I would try heating it up with a torch and quench it with pb blaster. You may need to repeat it a few times but I haven't found one that wont come off with that method.
Old Oct 24, 2022 | 11:29 AM
LetsGetThisDone's Avatar
That needs a gas axe. No saving it.
Old Oct 24, 2022 | 05:20 PM
Jaraxle's Avatar
That was my thought... There are NO THREADS visible anymore, and it is a rusted solid unit. Cutting it is the only way out.
Tagmaster12
Apr 17, 2015 12:03 PM
Evold_one
Oct 2, 2010 05:07 PM
asdfasdf128
Apr 26, 2008 01:48 PM
evotico
Sep 13, 2006 12:06 AM
mitch44759
Lancer Troubleshooting
Jun 26, 2005 03:36 PM
