6-spd lost 4th gear question
Old Dec 7, 2022 | 10:07 AM
Prelude Guy's Avatar
Hi all,
I'm considering buying a 6-spd Trans that the seller lists as 4th gear not working.
I purposely interested in this transmission so I can get it rebuilt and upgraded for reliability.
Anything in particular I should look our for? Lasy thing is i want to end up paying more for tge rebuild than had i bought a working transmission.
From my research, this is a common issue.
Thanks!
Old Dec 9, 2022 | 10:38 AM
schuhie's Avatar
4th gear in the 6 speeds is the thinnest and therefore weakest of the bunch. It is likely wrecked along with the matching gear on the other shaft.
If you are getting it rebuild, this is all fixable and maybe even would get replaced if you do an aftermarket 6 speed gear set. As for if you'll spend more, I think its all a crap shoot but generally a good rebuild would do all the wear items anyways so it shouldn't matter much.
Old Dec 10, 2022 | 01:31 AM
Jonno99's Avatar
Don't just think it'll be a single gear, there could be extensive damage in there.
Old Dec 10, 2022 | 08:03 PM
kaj's Avatar
kaj
First, finding replacement parts is almost impossible.
Second, even if you can find the parts.. or even an upgraded gearset, the trans still has inherent build issues that you can't fix.
If you find a way to get it working again, the chances are very, very high that it will fail again, possibly in a catastrophic way that can't be repaired. It's not worth it. This is based on my experience with two 6spds that I went through because I REFUSED to swap in a 5spd. I loved the 6spd but it wasn't good for anything other than daily driving, which is definitely not what I use my car for, unfortunately. I went through two 6spds that ended up going to the dump because they became useless paperweights.
Old Dec 11, 2022 | 07:49 PM
LetsGetThisDone's Avatar
6 speed isn't worth fixing. It WILL break again.
Doctro X
Sep 8, 2019 12:03 AM
Evo9Jay
Jan 8, 2015 08:21 AM
mrm95
Oct 16, 2014 07:50 AM
Brsox10288
18
Mar 7, 2012 10:04 PM
therunningskier
Jan 10, 2009 06:53 PM
