Coolant air bleeder valve
Old Jan 20, 2023 | 05:26 PM
varv's Avatar
Hi. Does anybody knows if Evo 9 got some kind of coolant air bleeder valve?
Old Jan 21, 2023 | 04:39 PM
RSMike's Avatar
It does not.
I would recommend running one of the big and tall funnels that clips into the radiator cap position.
Run it up to full temp, burp the bubbles with a little revs (3000rpm or so) then allow it to cool.
Once it's cold, then remove the funnel and put the cap on.
Old Jan 22, 2023 | 05:57 AM
varv's Avatar
Thanks will do. I found a special set in my local shop.
Old Jan 22, 2023 | 02:43 PM
LetsGetThisDone's Avatar
We don't have a bleeder, and these car bleed very easily on their own with that bleeder funnel you found there. Just turn the heater on and let it warm up.
Old Jan 22, 2023 | 07:14 PM
ViciousLSD's Avatar
hmm i thought that air bubbles will just come out when it reaches radiator cap pressure and gets replaced by coolant from the reservoir
Old Jan 22, 2023 | 07:27 PM
Yes, but then the system is low. That funnel you coolant in it, so as air comes out, coolant goes into the system
Old Jan 22, 2023 | 07:39 PM
ViciousLSD's Avatar
I guess thats the professional method. I just run the engine and keep filling until it overflows and flowing thru the upper hose. I put extra on the reservoir. I should probably turn the heater on next time, it just never crossed my mind lol
Old Jan 22, 2023 | 07:44 PM
For <$20 or so for those funnel kits, it's just nice to not spill lol
Old Jan 22, 2023 | 07:59 PM
ViciousLSD's Avatar
true but I also eject all the coolant thru the lower radiator hose
Old Jan 23, 2023 | 03:22 AM
varv's Avatar
Btw what should be the correct level of coolant? I guess after completing this process my radiator will be 100% full but what about this expansion tank? To be honest I never saw any fluid in there
Old Jan 23, 2023 | 08:44 AM
Kevin.'s Avatar
It's an overflow tank, not an expansion tank like in a pressurized coolant system. If there's too much coolant, your overflow tube will dump coolant.
The jiggle pin on the thermostat helps the system bleed.
Old Jan 23, 2023 | 08:55 AM
With the radiator properly full, I usually just fill the expansion tank with a couple inches of coolant so it's not empty. Gives more expansion room.
Old Apr 6, 2026 | 10:56 AM
dekorum's Avatar
I recently returned my OEM tools kit because it was leaking out of the cap. Which kit did you get? I would like to find one that is truly leak free. I wonder if it’s because my radiator is an old CBRD one so the neck/cap isn’t exactly OEM.
aamoedo
Oct 28, 2016 09:22 AM
dragon831
Apr 3, 2009 11:54 PM
Master_French
Oct 12, 2004 10:58 AM
CromeOz
Lancer Engine Tech
Sep 25, 2003 06:35 AM
