Starting Engine for First Time
Old Mar 21, 2023 | 08:07 PM
Ashwnkr's Avatar
I just bought an Evo IX that may have been sitting for awhile. Any advice for making sure the engine is properly lubricated? Does disconnecting the fuel pump before cranking ensure proper lubrication in Evos or is there a better approach?
Old Mar 21, 2023 | 10:40 PM
Pal215's Avatar
You're probably fine just starting it and letting it idle for a while once you check the dipstick oil level. If you are really worried, you can disconnect the crank position sensor and crank it a few times until the oil pressure light goes off in the dash.
Old Mar 22, 2023 | 07:24 AM
RobbieOh's Avatar
5 Year Member
That^
Old Mar 22, 2023 | 07:26 AM
Ashwnkr's Avatar
Thanks.
Old Mar 22, 2023 | 08:03 AM
osetsky's Avatar
Mine sat for years and I did a couple drops of oil in through spark plug hole and let it sit a few days, fired up...well I did not expect it to when it did, there's a vid. Runs great!
Old Mar 22, 2023 | 08:13 AM
Ashwnkr's Avatar
Dod you also drain the gas tank or just add fresh gas? I'm not 100% sure how long mine was sitting before I got it.
Old Mar 22, 2023 | 08:23 AM
Ashwnkr's Avatar
Do you have a video link?
Old Mar 22, 2023 | 10:05 AM
Kevin.'s Avatar
You can easily drain the gasoline by using a 3/8 fuel hose on the fuel rail return and let it idle out. There's also two drain bolts on either side of the fuel tank.
Old Mar 22, 2023 | 04:40 PM
osetsky's Avatar
I did drain from the bottom plugs and use fresh fuel.
Old Mar 22, 2023 | 05:08 PM
Ashwnkr's Avatar
Thanks.
Old Mar 23, 2023 | 09:04 AM
osetsky's Avatar
Old Mar 23, 2023 | 06:28 PM
Ashwnkr's Avatar
Thanks.
Old Mar 23, 2023 | 07:30 PM
Ashwnkr's Avatar
Thanks.
Old Mar 23, 2023 | 07:31 PM
Ashwnkr's Avatar
Thanks.
Old Apr 5, 2023 | 07:15 AM
mr.Freddy's Avatar
The best way to start in my opinion would be:
1. Check the oil level. If low add to max level
2. If low level of fuel add at least 5 gallon of fresh gas. If you got full tank - sucks, better to drain and add some fresh gas. Gas gets bad over time. Octane number tends to drop down as it sits in a tank for a long period of time
3. Remove ALL spark plugs (and inspect them as they are out)
4. Crank the engine with starter until the low pressure oil light goes off Do not crank for more then 10 seconds at a time - may overheat starter. Give it some time to cool off
5. Put the spark plugs back. Do not over tight!
6. Check coolant level and fire up the engine! Let it idle and warm up till the fans kick in Make sure it's not gonna boil the coolant for some reason
7. Replace engine oil and filter with fresh ones
8. You're good to go!
Adam Keith Lang
Jan 13, 2016 04:18 AM
EDDIE12
Mar 19, 2015 07:10 AM
ak47po
10
Jul 8, 2012 12:36 PM
spindoctor1203
Lancer Troubleshooting
Jun 20, 2012 07:02 AM
RS2
May 8, 2005 10:00 AM
