Green, 54 Green or AGT 52mm to replace my 71hta?
Old Nov 17, 2023 | 04:46 AM
  #31
Abacus's Avatar
Originally Posted by schuhie
Probably something like that? There are a lot of variables when determining when the turbo will spool but there is about a 500rpm difference from the green to the red.
The setup you are looking at is pretty common with both the green and the red so I'd go hunt through the dyno results section and see if you can find a few examples of each to compare and make a decision from there.
I disagree. Its closer to 250-300rpm from green to red (MHI housing) on the 9.
Regardless of what it is we've got an engine that goes proud and reliably to 8000+ rpm. All the bolt on turbo's nose over but the red is still a perfect match for a fun street car 3800-8000. The green is still to small IMO on the 9.
You also have to respect the 400lb ft rule at low rpm's with the boost controller. You can exceed that with the green or red below 4000 so the earlier spool up of the green doesn't help that on a stock engine. Furthermore, Too small of a turbo/boost at low rpm can cause compressor surge because the engine can't ingest the air.
The green or red will still come up hard enough to powerslide the car or break differentials at low speeds. The red will just continue to pull over the green until redline.
Old Nov 17, 2023 | 07:45 AM
  #32
LetsGetThisDone's Avatar
I don't like the 71hta. It's comes on too hard even at part throttle, makes the car annoying to drive for me.
I would do a green or 18k.
Old Nov 17, 2023 | 10:38 AM
  #33
Jahtoot's Avatar
Lots of good quality information here on turbo's. After re-reading this thread. I think I will focus on making my setup solid around my evo 9 turbo.
I have always been satisfied with stock turbo Evo's on a 300-350whp setup/tune. Straight line driving just doesn't get my adrenaline pumping as much
Once that is established, I can upgrade to a FP RED with some S2 cams. (if I really wanna notch up the power).
Old Nov 17, 2023 | 12:34 PM
  #34
Lazyfong's Avatar
How is the reliability and spool of AGT compared to FP?
Old Nov 17, 2023 | 12:49 PM
  #35
Jahtoot's Avatar
Great question. Alot of dyno charts are on AGT IG and FB pages.
Its not a bad product for the price, but no idea on reliability since its a fairly new turbo production.
Not much on these forums about AGT as well, tons of information on FP here tho.
Great question though, id like to see some responses and reviews of AGT turbo's
Old Nov 17, 2023 | 01:34 PM
  #36
Kevin.'s Avatar
I just put a modified 9 turbo on by AGT. Everything looks good in the ~500 miles since tune.
I'd like to see durability of one that sees the track being that it's a low cost turbine housing I believe
Old Nov 17, 2023 | 01:54 PM
  #37
Revolver Ocelot's Avatar
Yea, losing 300rpm doesnt seem to bad, for what you get.
On a street/canyon stock block car that might see less than a handful of tracks days would you still go green over red?
Old Nov 17, 2023 | 04:43 PM
  #38
FP spools better and make more power.
Old Nov 22, 2023 | 08:15 AM
  #39
Evo9isLife's Avatar
5 Year Member
FYI, AGT is currently running a black friday sale 5% off turbos
Thore
Jan 22, 2011 05:46 PM
94AWDcoupe
62
May 20, 2010 05:29 PM
kemoly
31
Sep 4, 2009 09:02 AM
Nasty Evolution
24
Nov 28, 2008 09:08 AM
Mark H - Evo 8
100
Jul 27, 2008 07:22 AM
