Rattling noise
Old Dec 16, 2023 | 01:38 PM
varv's Avatar
Santa came earlier this year 🎅🏻🎁
I paid 1400 $ for upgraded transfer gear set from Brena including shipping. That is less expensive than Mitsubishi one lol.
Old Dec 16, 2023 | 09:16 PM
ViciousLSD's Avatar
Nice. notice TRE grinds the gears and rounds off the edges of the tooth. maybe you should get the done
Old Dec 18, 2023 | 07:50 AM
varv's Avatar
I asked them about it before ordering. I was surprised because they replied that this is what they do for most companies they are selling stuff to. So they did for me lol. Maybe TRE does it second time 😁
Old Dec 18, 2023 | 08:19 AM
ViciousLSD's Avatar
that seems to be the shiny smoothness. I was talking about grinding the edges.
Old Dec 18, 2023 | 09:49 AM
varv's Avatar
And for what should I grind the edges? 🤔
Old Dec 18, 2023 | 10:26 AM
ViciousLSD's Avatar
I think the idea there is the edges crumble eventually and get in between the gears and cause more issues. grinding them off skips all that.
TRE seems to be rounding off the pointy end of the ring also
Old Dec 18, 2023 | 11:58 AM
varv's Avatar
Thanks. I know someone who deals with transfers and diffs, it's possible they do this too.
Old Feb 20, 2024 | 02:22 PM
varv's Avatar
Ok so it came out that pinion teeth were eaten (i'll make photo tomorrow). Inside transfer there was black goo everywhere, which probably resulted from grinding the elements. I'm not sure if the oil was good quality or filled properly, because it looked really bad. I found information that proper oil for ACD Transfer box is GL5 spec LS 75w90. Can anyone confirm it? And the part with several clutch discs is lubed by this same oil? Or hydraulic oil from ACD?
I found a guide how to "properly" fill up transfer case:
https://www.jackstransmissions.com/b...t-case-filling
I would like to know your opinion whether this is really necessary
Old Feb 20, 2024 | 03:35 PM
ViciousLSD's Avatar
I use SAE90 for the front diff. redline 75w90 too in the past. The LCD locks left-right axles and it needs the previously mentioned gear oil. The ACD is what manages the front-rear power transfer. This is pressurized by hydraulic fluid or ATF
Old Feb 21, 2024 | 03:10 PM
varv's Avatar
I made some photos. Those teeth get sharpened like razors and most of material was transformed in this strange metallic goo that plugged absolutely everything. I used 6 bottles of solvent to remove it from the case. Is it possible that the wrong oil was used?
Old Feb 26, 2024 | 02:18 PM
varv's Avatar
I went thru steps described here https://www.jackstransmissions.com/b...t-case-filling and 0.8 quart went inside, not 0.6 as specified on forums. I'm not sure how filling transfer case thru tail housing allows pouring 0.2 more, but it's worth checking.
Anyways, now everything work perfectly and rattling noise has gone! Thanks everyone for help
Old Mar 1, 2024 | 06:30 AM
WRC-LVR's Avatar
That is just nasty. lot of ground up metal in there
remusrm
AWD Lancer (2012 +)
Dec 26, 2016 08:45 PM
NMX
May 23, 2011 07:04 PM
Spanishevo
24
Feb 15, 2011 12:09 PM
cjdwyer24
Jan 20, 2011 04:12 AM
ashton13
Oct 19, 2005 03:28 PM
