R2 cam valve springs.
Old Mar 20, 2024 | 05:45 AM
DSMolition's Avatar
Swapping from kelford 272s to gsc r2 cams. I don't rev past 8500 with my 2.3l fp black setup. Will my kiggly street steel beehive springs be fine or do I need to buy the high pressure with ti retainers? Both are capable of 0.500 lift and cam max lift is 12mm so I should be good if I'm understanding it right. I reached out to kiggly with no reply along with some others so looking for opinions. Thanks.
Old Mar 30, 2024 | 03:06 AM
Fireescape's Avatar
Best springs you can get in my opinion. Have had R2's installed in my 9 for years with GSC 5041 springs and titanium retainers. Lost a valve spring about a year ago, snapped in half, valve dropped down and hit the piston, got pushed back up and hit the cam which bent its shaft and locked it up in the head, saving the engine. I can only assume the spring failed due to fatigue, maybe not helped by the high lift that R2 cams have. I ended up replacing the complete set of springs and retainers (and a new valve, retainers, rocker etc) with another set of 5041's, don't know if any other springs would be better, but I certainly wouldn't put anything potential less capable in, you'd definitely want the best ones available for the job.
Old Mar 30, 2024 | 08:22 AM
LetsGetThisDone's Avatar
How many miles were on the spring? We usually replace them on refresh's as we start to see a larger variance in rates. Especially with the high lift of S3's or R2's. GSC's new conical springs do very well. But like anything else, things have a life cycle when building racecar stuff.
Not sure what your power goal is, but if it's sub 800whp. I'd probably go to an S2, especially if it's not a racecar.
Old Mar 30, 2024 | 01:13 PM
240Z TwinTurbo's Avatar
Same thing happened with my GSC springs, but with S2 cams. Ended up using the Kiggly behive high pressure springs and converted to R2, which was probably 10+ years ago.
Old Mar 31, 2024 | 03:51 PM
dr_latino999's Avatar
Veteran: Army
I guess 12 years with S2's should tell me to change my springs before grabbing R2s. Are R2s that big of a difference [2.2L] that they aren't reasonable for the street?
sssr20det510
May 11, 2018 11:14 PM
SmurfZilla
44
May 4, 2012 09:33 PM
Steve@NoLimitmotors
May 15, 2007 11:37 AM
evo3matt
Apr 13, 2006 10:07 PM
4-BNGR
Jun 25, 2005 02:31 PM
