Need some help troubleshooting....
Old Apr 24, 2004, 05:19 PM
Epidemic's Avatar
Unhappy Need some help troubleshooting....
I'm posting on my friend's screen name. I drive a 03 black evo. And I need some help troubleshooting. My mods are megan racing catback exhaust (second o2 sensor is not attached), apexi SAFC, AEM intake, Turbo XS MBC, Walboro 255 fuel pump, ralliart sparkplug wires, and 1 step colder NGK iridium.
I was doing some AWD burnouts in circles, and the car was running fine until I got off the gas. The car started bogging and died. I thought it was my IC piping or I was running real rich. I look over all my IC piping and everything was good. Than I assumed my engine was flooded with fuel. I checked my sparkplugs, disconnected the fuel pump, and cranked the motor w/o the plugs to get excess fuel out. Than I cleaned the fouled plugs and put them back in. The car started, but it sounds boggy and there is loud pops out of the exhaust that sound like cannon shots. I assumed my car was missing, but all plugs seemed to be getting spark. I have not tried to drive with it in this condition and wanted to know if you guys had any input on what the problem might be. Thanks!
Old Apr 24, 2004, 07:33 PM
Epidemic's Avatar
*BUMP*
Old Apr 24, 2004, 07:36 PM
mprtklr's Avatar
to fix i dont know...
the problem??
this
Old Apr 24, 2004, 07:38 PM
evodaddy's Avatar
Did you get a check engine light of any kind?
Old Apr 24, 2004, 07:57 PM
Epidemic's Avatar
the problem??
this
Thanks for the info... you are alot of help . I realize it was a stupid idea, but it's already done. Now I am looking for technical help not criticism.
Old Apr 24, 2004, 07:58 PM
Epidemic's Avatar
I had a previous check engine b/c of the o2 sensor. After the car died we reset the battery and no check engine. The next day we came back to the car and now a check engine light is on, we are going to get a OBDII and try and read the code.
Any input anyone?
Old Apr 24, 2004, 07:59 PM
Epidemic's Avatar
When I checked the plugs they were very black (rich) and after i cleaned them and drained the engine of fuel I put them back in,(and even tried some others).
Old Apr 24, 2004, 08:24 PM
evodaddy's Avatar
Post what the CEL is when you get it. It maybe the plugs but the CEL will help you see what's going on.
Old Apr 25, 2004, 01:38 PM
AWDOWNZJ00's Avatar
bump
Old Apr 25, 2004, 03:47 PM
AWDOWNZJ00's Avatar
This is my car btw I dont have and OBD II reader. The car idles like crap when I give it gas it sounds like a V8 and it wont go over 3500-4000k rpm and gets there very slowly. When I turn the car on there are a few loud pops from the exhaust and if I give it any gas it will start poping when I let off the gas. I am guessing this is a limp mode can any of yall give suggestions besides spark and intercooler piping that could cause this?
Please dont post anything unless you have a suggestion*
Old Apr 25, 2004, 04:17 PM
AWDOWNZJ00's Avatar
anyone?
Old Apr 25, 2004, 05:24 PM
Nad1370's Avatar
It could be your MAF meter that took a sh** .Maybe its giving incorrect signals going to the Ecu. Check your MAF meter if the sensor wire is contaminated by dirt or grime. If it is , spray it with brake cleaner and blow it of with a blow gun. ( check if its still plugged in)
Or it could be a TPS ( throttle position sensor ). Its located on the throttle body. Check if its still hooked up, it could've jarred the connector loose while you were doing your st*** stunt.
Or maybe its as simple as a poped intercooler hose.
Old Apr 25, 2004, 05:28 PM
evodaddy's Avatar
It could be 1,000 things, get a OBDII reader man.
gregivq
Lancer Engine Tech
43
Dec 2, 2018 09:23 AM
krisdlm
21
Mar 29, 2018 07:26 AM
Syrihl
11
Feb 4, 2012 02:32 PM
billevo1x
15
Oct 4, 2009 05:01 AM
Darklancer
Lancer Troubleshooting
Jan 8, 2006 10:09 PM
Quick Reply: Need some help troubleshooting....
