Anyone removed the exhaust flap?
Old May 14, 2004 | 07:57 AM
Nellie's Avatar
Hey Guys & Gals:
Anyone removed the exhaust flap in their muffler? I know WORKS have under their SkunkWORKS 'project' and although their are no (or very minimal) performance gains, if beefs up the exhuast note at idel.
Just wondering.
Old May 14, 2004 | 08:44 AM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by Nellie
Hey Guys & Gals:
Just wondering.
What and where is it? Can you post pics? Sorry for the stupid question
Old May 14, 2004 | 08:59 AM
boomn29's Avatar
WTF??? Same here.
Old May 14, 2004 | 09:03 AM
OnlineAlias's Avatar
There's a flap inside the muffler that lifts out of the way at higher RPM. It just lays there. Someone removed it on the boards, although I don't know if they said it did anything..
Old May 14, 2004 | 09:25 AM
I looked at my stock muffler. Is it the peice at the bottom of the pipe that connects to the rear section of the exhaust? That was all I could see. The muffler has the almost 90 degree turn inside but looks straight through.
Old May 14, 2004 | 09:31 AM
justchil's Avatar
There was a post on this a long long time ago... The guy said it was a real pain the *** to get the flap out.. better off buying a muffler or catback IMHO
Old May 14, 2004 | 09:36 AM
Nellie's Avatar
robertaustin:
Yeah, I think so. I'm guessing you can get to it by dropping the muffler from the pipe and access it through the resulting fitting hole (if you see what I mean). There's a diagram of it in the service manual and it's literally a flap which (I'm guessing) is opened or closed depending on exhuast flow.
I was hopoing someone had already done it and could post some notes.
Again I don't think it does anything performance wise, just adds a few more DB's to the exhaust sound.
Nellie's Avatar
Justchil:
Bingo! Thanks.
Old May 14, 2004 | 09:49 AM
matt55's Avatar
I did it a while back , it was a piannnn , the biggest improvment was the boost came on alot quicker. AND I didnt hear the flapper door slam close any more. (For some reason I lesten too closely some times)
Old May 14, 2004 | 10:26 AM
EvolvedDSM's Avatar
http://www.columbusdsm.com/forum/viewtopic.php?t=4511
I wouldn't even bother
Old May 14, 2004 | 10:27 AM
Zeus's Avatar
It's spring loaded and it requires the exhaust pressure to push it open... you can easily see it if you pull the muffler. I looked at it, but diidn't see a "clean" way to remove it.
Old May 14, 2004 | 10:21 PM
Mike W's Avatar
I have done a few. Easiest is to use a piece of rod to hold it open. Get a piece about 6 to 8 inches long. Stick it into the muffler inlet so that it holds the flapper open. Weld the rod to the inside of the pipe just inside where you can get the MIG welder into it. Takes about 5 minutes.
Mike W
Old May 17, 2004 | 10:03 AM
Nellie's Avatar
Thanks Mike - nice post and best option I think.
Nellie
Old May 18, 2004 | 04:34 AM
matt55's Avatar
I took off the muffler and with a long screwdriver and hamer I made mine stay open by beating on it . Look like **** inside but it was all balck as soon as you run the car. This was pain it da *** to do also. But I "felt" a diffrance in spool up.
Old May 18, 2004 | 06:19 AM
GottaGoFaster's Avatar
My Buschur Muffler delete pipe does not have a flap
Briggamortis
09+ Ralliart Show and Shine
May 4, 2017 07:25 AM
ToLate24
Dec 13, 2016 11:22 AM
mlau1294
Dec 30, 2015 06:40 PM
TxFAkuma
Oct 5, 2015 01:44 PM
mot
Jul 11, 2006 07:25 AM
