next mod
Old May 17, 2004 | 12:33 PM
ammitsuevo's Avatar
next mod
hey all. what should i do next? here are my current mods--- i,e,dp, mbc, afc
what next? cams and cam gears? ic piping and bigger ic?
thanks
Old May 17, 2004 | 01:11 PM
tama_mog's Avatar
cams and cam gears will yield good gains for your setup.....with some tuning of course. The gains from a bigger IC on a stock turbo is minimal in my opinion...but definitely should be in consideration as you start getting a bigger turbo.
Old May 17, 2004 | 01:32 PM
Kyperion's Avatar
BRAKES..
new rotors and pads.
Everyone is always about making stuff go really fast, but you need to also consider you have to stop it.
Old May 17, 2004 | 03:03 PM
twan's Avatar
Id finish off the TB exhaust to a full 3" then some injectors / pump, finally complimenting it with some sorta flash.
Old May 17, 2004 | 06:22 PM
ammitsuevo's Avatar
thanks to all who have replied so far. am planning to address all aspects of the car, not just making it go fast. howver the stock brembos are preety good imo for the mods i have, but i understand what you are saying
Old May 18, 2004 | 07:15 PM
ammitsuevo's Avatar
any other suggestions? thank you guys
Old May 18, 2004 | 07:17 PM
projekzero's Avatar
id look into cams, gears, and a flash next. imop
Old May 18, 2004 | 08:07 PM
raywong's Avatar
stock brake was not enough even for stock power for me. simple upgrade such as performance brake pad and steel brake line give me confidence to go faster.
Old May 19, 2004 | 06:06 PM
ammitsuevo's Avatar
i feel you. better pads and lines are on my list as well, i just meant to say that the stocke brakes are not crap you know.
Old May 19, 2004 | 07:43 PM
berkel's Avatar
Hey,
I have a similar situation.
My plan is as follows. Get new brake pads, ss lines, change the fluid. I don't think I'm going to change the rotors at this point.
Upgrade the clutch to ACT with machined stock flywheel.
Now get to the next level of perf mods with cams, cam gears, and a flash. I already have an upgraded fuel pump, but if necessary I could do the injectors as well and get it all dialed in with the flash.
I think I'll be more than happy with that, but the next step would be a turbo upgrade, along with larger intercooler and all that, but tha's a distant dream at this point, heh.
Take care,
FB
Old May 20, 2004 | 06:02 PM
ammitsuevo's Avatar
thanks for the reply man-i understand what you mean when you say a distant dream- it is true, so many mods not enought cash!
