The Turbokit is out and it's sick
Old Jun 4, 2004 | 11:54 AM
  #76
evo_dadi's Avatar
Originally Posted by 4G63>OOOO
Besides, getting full boost at 2700rpm is a LOT more fun than waiting until 4500 for a big boy to spool. But it's all about what you're into, right?
dayum!!! 2700 rpm!! what mods have you done man? im planning on staying with the stock turbo for now till i rebuild the engine.im also looking on gettin the works water injection so i can run higher boost w/o much worries on 91 **** gas.
Old Jun 4, 2004 | 12:13 PM
  #77
4G63>OOOO's Avatar
Water injection will definitely help you out there. That's the only reason I can run 24psi on pump gas.
Old Jun 4, 2004 | 01:14 PM
  #78
bolsen's Avatar
Originally Posted by Az3ar
I am getting this turbo next week I will let you guys know.
You won't be disappointed.
Old Jun 5, 2004 | 04:47 PM
  #79
Smogrunner's Avatar
Hey guys,
I'm very interested in the 3071 setup, here's why: my car is a daily driver that I drag race about once a month (and at some point plan to road race). I run low 12s with my current setup and don't really want to have to install a roll cage in a car that I often have to put my 1 and 6 year olds in. I figure this setup will be good for easy and consistent high 11's, which still might get me kicked off but usually one can bull**** the track folks if it is still close to 12 flat.
On the Vishnu dyno, my stage 1+ made 311whp on race gas (c16) and 275 on 91. That is with the turbo back exhaust, hks 264/272 cams, cam gears, xedeflash, upgraded bov and fuel pump (I have stock intake). If I was to add the 3071 kit and larger injectors, what dyno numbers could I expect to see with this setup and a custom tune by Shiv on his dyno?
Old Jun 5, 2004 | 05:31 PM
  #80
Az3ar's Avatar
alot of power. aroung 400 whp
Old Jun 5, 2004 | 10:48 PM
  #81
IE Evo's Avatar
Smog, What is up. You reading my mind or my emails/ pms. I guess you are and as you know from them that I believe this kit is the way to go. Low 12s on pump like 12 flat maybe and probably mid 11s-11.7 with mere mortals like me and you driving. Now put Audi/John Force/Big daddy Don Garlitts behind the wheel and maybe 11.3s. I will be happy with low 12s on pump and 11.7 on race gas. But then again I thought low 12s would keep me content. I will PM you I got some interesting track results to share with you. OUT!.
Old Jun 7, 2004 | 07:02 PM
  #82
bolsen's Avatar
Bump
Old Jun 7, 2004 | 09:03 PM
  #83
Az3ar's Avatar
I will let you guys know how it preform by the end of the week or early next week
Old Jun 7, 2004 | 11:20 PM
  #84
wilson1's Avatar
Did you get it already?
Old Jun 8, 2004 | 02:58 AM
  #85
Lowness's Avatar
I got the stock turbo to do 360whp...and that was before the water injection.
yea, but at 360whp the stock turbo is nearly maxed out on pump gas with all your supporting mods.
The ATP GT3071R turbo upgrade is only starting to make power at 375 whp. They only had 660 injectors, 3" exhaust, moddest boost settings, and some tunning. I'm assuming this is on pump gas. If you add cams, FMIC, and other supporting mods it will get you alot more power.
This turbo kit is cheap and spools up 200-300 rpm later than stock. This turbo upgrade kit is definately on the top of my list.
Old Jun 8, 2004 | 04:14 AM
  #86
barracuda25's Avatar
on top of mine too....and Az3ar pls post feedback on this 3071 which I'm sure I'll be getting abt 2weeks from now.
Old Jun 8, 2004 | 06:07 AM
  #87
Smogrunner's Avatar
Az3ar,
Who will be tuning and dynoing it after you put it on? What ems do you have?
Old Jun 8, 2004 | 08:56 AM
  #88
Az3ar's Avatar
I dont know who will do it yet as I moved to OC, CA recently and I dont really know anyone around here that i can realy trust. My friend from work and I will be installing the turbo kit which not hard at all as I have installed and worked on cars many times. here is what I got with my turbo kit. 750 injectors, 255 W fuel pump and AFC 2. ATP asured me that with this setup I should be around 360 whp on 91 gas. However in few months I will be buying AEM EMC or utech to top everything. Do you guys how much I should trq my injectors??? or if the turbo require special torqing on the manifold?? I have a trq ranch however. I dont know what are the tq specs??? any help will be great??? any instructions on installing afc on EVO??
Old Jun 8, 2004 | 09:02 AM
  #89
tama_mog's Avatar
do a search I think, a lot of instructions on hooking up afc....I think as long as you got the harness you'll have a easy time installing it. Good luck with that kit, I'm curious to see the results as well. =)
Old Jun 8, 2004 | 09:12 AM
  #90
Az3ar's Avatar
harness??? I was gana splice some wires I have always done it this way and it worked great. Where can I get the direct harness?? and how much??
