External Wastegate
Old Jun 26, 2004 | 10:22 AM
masterevo's Avatar
External Wastegate
Hey guys, I have been pondering about this for a while. How is the external wastegate whistle if it does at all comparing to the whistling sound of a BOV? Is it loud like a BOV? From what I understand, the ext. wastegate release pressure built inside the turbo and so it performs in the same manner as the BOV releasing pressure inside the IC. Is that true? Well, just curious...
Old Jun 26, 2004 | 02:48 PM
Tofurky's Avatar
doesn't really sound like a BOV... sounds more like an open header
Old Jun 26, 2004 | 03:22 PM
EVOVII_SWE's Avatar
Nope, the BOV dumps pressure either to atmosphere or back to the intake side of the turbo when you let go of the accelerator. This is to prevent very high pressure between the closed throttle and the turbo which slows the spinning turbo fast and it then takes longer to start spinning it again and produce boost. Also that high pressure can damage the turbo in the long run.
The wastegate is what controls how much of the exhaust gases that passes through the turbo and thus controls the boost. Normally the wastegate vents back to the exhaust pipe and you don’t hear much of it. You could have an open wastegate dump and much as Tofurky said that would sound like an open header. Hope this cleared some question marks?
Old Jun 26, 2004 | 03:51 PM
marksae's Avatar
A wastegate throttles the amount of exhaust gas that passes through the turbo, which is how it controls boost. I had an external dumping o2 housing on my 1g. It was cool at first, but go old quick. The noise was unbearably loud and everytime the wastegate opened, all the exhaust fumes would enter the cabin. Not cool in a street car IMO. You can always route the dump tube to go out the side of your bumper though. A few RRE cars do.
Old Jun 26, 2004 | 04:05 PM
SilverEvo8owner's Avatar
quite simply
when a wastegate opens up, it sounds like your downpipe fell off
Old Jun 26, 2004 | 04:15 PM
SSKILLA's Avatar
can a external wastegate be put on the stock turbo??
Old Jun 26, 2004 | 05:00 PM
marksae's Avatar
You can put an externally dumping o2 housing on. Then your internal wastegate could dump to atmosphere. Or you and weld an external wastegate to your exhaust manifold and keep the stock turbo's internal wastegate closed.
A wastegate is just a valve that modulates how much exhaust goes through the turbo. You can place it anywhere between the engine and turbo.
Old Jun 27, 2004 | 11:46 AM
SSKILLA's Avatar
how would you keep the stock one closed to be able to mount the external one?
Old Jun 27, 2004 | 03:36 PM
masterevo's Avatar
Thank you guys for the info. I'm giving a good thought on the BR500. Cheap and it works.
Old Jun 27, 2004 | 06:15 PM
marksae's Avatar
Mount the wastegate off the exhaust manifold.
eking
Jan 1, 2014 04:43 PM
jonmorera
Oct 30, 2011 10:32 PM
CrawlinTBSS
12
Sep 29, 2011 05:42 PM
nnorris7413
57
Sep 18, 2005 02:52 PM
GOKOU
Jun 21, 2004 10:35 AM
