Aftermarket oil pans
I need to find a site for after market oil pans. One that has a larger capacity and built with better materials. Any help will be appreciated
Believe or not I can't find anyone offering it here in Japan !!!
Thanx
PS I own EVOIV GSR.
Thanx
PS I own EVOIV GSR.
I have to ask, why??? I can’t imagine a reason for wanting more oil.
The oil pan on the E4, like the E5 lacks some of the baffling added to the E6. This was to prevent oil starvation under hard acceleration. Perhaps swapping the pan from an E6 would help?
Those reasons just didn’t spring to mind. As I age I am afraid that my thinking is becoming rather set. I tend to see only the obvious.
The Evos all carry pretty generous oil coolers. There are upgrade options for the stock oil cooler that should get the job done. Shorten the oil change interval if you are concerned that you are endangering the engine. With a turbo charged car I would use full synthetic oil, which typically will give good service.
Looking for a custom oil pan just sounds like an unnecessary hassle.
David Buschur
83
May 27, 2016 07:39 AM
All points taken... I decided to just add a fan(pull) to my oil cooler(HKS)..waiting for parts as we speak.
