Having problem with injector clips
Old Jul 7, 2004 | 09:24 PM
RichJ's Avatar
Does anyone have a suggestion for the best tools to use to remove the wire clips on the injectors? I got one off, but it took forever, and now I'm also having trouble unhooking the harness even with the wire clip out. Not sure how to get it unhooked from the harness or whether I need to pry from the bottom with a little screwdriver or something.
Thanks for any suggestions.
RichJ
Old Dec 9, 2005 | 06:52 PM
4TUN8's Avatar
I'm having this same problem atm. There are no real good injector install howto's on this site.
I need info on getting the electrical clips off the injector.
Old Dec 9, 2005 | 07:01 PM
bolsen's Avatar
The clips are under a small lip to hold them in. You need to essentially pull the clip out a bit and then pull up. Just take a small flathead screwdriver and slip it between the lip and twist up. Careful, they'll go flying!
It's not that tough to do, a flat head screw driver will work perfect!
Old Dec 9, 2005 | 09:48 PM
4TUN8's Avatar
it has a little metal band that needs to come out, I figured that part out and it made it much easier.
Old Dec 10, 2005 | 05:12 AM
EvoTech's Avatar
Do not loose those clips! You can not buy new ones from mitsubishi.
Old Dec 10, 2005 | 05:22 AM
MrMejia's Avatar
they break easily too so "be very careful". Finesse and take your time.
Old Dec 10, 2005 | 06:00 AM
4TUN8's Avatar
I lost one and I fabbed a new one out of one of those keytag holders that the dealership puts on your keys to keep track of them. Worked just as well.
Old Apr 26, 2011 | 12:01 PM
dastallion951's Avatar
i just bought a 25 pack for 40 from napa auto parts....so if i lose em or break em **** it haha as long as they dont get wedged anywhere haha
Old Apr 26, 2011 | 01:47 PM
bambooi's Avatar
You can also make them out of paper clips. I think CBRD uses a thin wire and then twists the ends tight to keep them from coming off. If they need to remove it, they just cut it.
Old Apr 26, 2011 | 07:42 PM
Silk's Avatar
Wholly thread revival
tjwphoto
67
Apr 4, 2020 02:32 PM
D Grade
AEM EMS
Sep 10, 2009 04:01 PM
alkatraz05
Apr 20, 2008 07:04 PM
projekt_shocker
Jan 14, 2008 11:16 AM
RichJ
20
Jan 5, 2004 09:43 AM
