HOW TO: get rid of stinky Check Engine Light (test pipe) (HFlowC)
Old Jul 10, 2004 | 08:14 AM
tweakdsm's Avatar
www.o2simulator.com $30 bux shipped! in 3 days you will receive o2 sim in mail....
What i did:
1) remove passanger side seat (4 screws) dont forget to remove rear center console (2 screws) there is an opening in carpet to get to rear o2 sensor.
2) you will find connector inside remove it, cut the white wire before the connector and connect it with white wire on the o2 sim, other end just leave it alone.
3) red/yellow wire color is +12, (splice connect with blue on o2 sim)
4) black is ground (no doh) (splice connect with black on o2 sim) thats all!
dont forget to disconnect your - terminal before installation, use electrical tape
thats all no more ce light (o2 sim led with blink every 10sec or so)
Hope this helps, later...
Old Jul 10, 2004 | 08:28 AM
hyp36rmax's Avatar
you already solved your awnser, otherwise if you decied to get your car tuned, you can have the tuner reprogram that particular cel out....
Old Jul 10, 2004 | 08:33 AM
Az3ar's Avatar
did that really work because I am about to do it. are you sure?
Old Jul 10, 2004 | 08:34 AM
Evo H8's Avatar
Thanks for the tip. I just ordered one.
Old Jul 10, 2004 | 08:37 AM
sleet's Avatar
I got no cat or anything and I don't get a CEL light, I have an o2 stimulator but I don't have any need for it now.
Old Jul 10, 2004 | 08:42 AM
Az3ar's Avatar
so that trick wont work with out that O2 part right? I will have to order it?
Evo H8's Avatar
Did you get the dual or single output type?
Old Jul 10, 2004 | 10:10 AM
tweakdsm's Avatar
single sir.
Old Jul 10, 2004 | 02:46 PM
umiami80's Avatar
I put one of these on, still doesn't work, IDK what to do....
SsZERO
Mar 15, 2019 01:40 PM
KDamericano
Jun 11, 2006 11:00 AM
mcbrown35
Lancer Aftermarket Forced Induction Tech
Feb 24, 2005 07:20 AM
deekay247
Dec 15, 2004 12:01 AM
GTVEVO
May 26, 2004 01:11 PM
