For those with MBC's...
Old Jul 11, 2004 | 05:55 PM
BLiu's Avatar
Do you need a boost gauge to adjust the MBC? Or is it stand alone? If I don't need the boost gauge, then could you please tell me how the MBC can be adjusted to a certain psi? Thanks!
Brent
Old Jul 11, 2004 | 06:00 PM
WannaRace's Avatar
Unless you have some way of monitoring boost, you won't know what your doing with a MBC
Old Jul 11, 2004 | 06:01 PM
kuniboy's Avatar
Dude, are you serious? I guess you must be. The answer is yes! You do need a boost gauge to set the proper psi for the MBC.
Old Jul 11, 2004 | 06:51 PM
BLiu's Avatar
Just Doublechecking...
Brent
Old Jul 11, 2004 | 06:53 PM
93civEJ1's Avatar
standalone??? what???
Old Jul 11, 2004 | 07:17 PM
chickenbrest's Avatar
yes you definately need something to read the PSI... then make a "small" adjustment....drive your car...watch the boost gauge.... then make another "small" adjustment...drive your car....watch your boost.....etc.....continue until you get to the desired PSI level.
Old Jul 12, 2004 | 12:53 PM
jk_addict's Avatar
My problem is this. I have an accel problem, where it hesitates at 4500-5000 2nd-5th. I installed a boost guage (autometer) to see what the psi was doing, and it gets up to , and at best it gets to 17 or 18. Even if you have a guage, how do you know you can trust it? I guess I should just have more faith huh?
Old Jul 12, 2004 | 01:00 PM
siantjab's Avatar
If you have the gauge installed and no boost control it should peak at about 19psi (max) and settle to around 17.5psi. So if you are using stock boost control and you are only seeing 18psi you can equate that the gauge is about 1psi off; or you have another issue (more likely the issue).
I've installed several different boost gauges (from autometer to defi) and I've not hit a deffective one yet. This is not to say that they can't be deffective; it's just unusual. If you don't have faith in your gauge get a new one. Another autometer will only set you back 60 bux; but you'll get the peice of mind knowing it's correct.
BTW, of course you need a boost gauge if you're going to tune an MBC.
dragon831
Nov 28, 2008 04:43 PM
wickedwhiteIX
Jan 15, 2008 03:00 PM
mitch44759
Lancer Aftermarket Forced Induction Tech
25
Mar 31, 2006 02:11 PM
EVIL EVO 8
Oct 28, 2005 06:37 AM
sirloin1219
Oct 6, 2005 10:00 AM
