Header question
Old Jul 21, 2004 | 01:05 PM
SEVEN's Avatar
Header question
I am considering installing a header in my EVO...i have stock turbo, HKS DP, HKS cat back B&B cat-delete pipe.
How many HP could i gain with the header?
Will apreciate your help guys
Thanks in advance
Old Jul 21, 2004 | 01:12 PM
DrMerl's Avatar
Consider that headers have the tendency to crack in turbo applications (unless you get some goods ones (321 stainless iirc) and the engine is just a convenient heat pump for the turbo. For stock turbo applications it might be better to P&P the stock manifold and have it coated. It's also good at keeping gases hot.
Old Jul 21, 2004 | 02:47 PM
Z1 Performance's Avatar
I honestly would not bother with a replacement manifold on the Evo unless your turbo choice (ie something other than stock) necessitates it, or if you want the look factor. The stock manifold is pretty large inside, and not really a whole lot of porting can be done on it
adam
floating doc
Jan 18, 2017 11:29 PM
BABYEVO1
55
May 9, 2014 08:18 PM
m3ta11ica12345
Lancer Engine Tech
Aug 25, 2008 07:28 AM
EE
Nov 12, 2007 02:53 PM
Nero
Lancer Engine Tech
10
Dec 16, 2003 09:15 PM
