How to do a proper compression test on Evo?
Old Jul 22, 2004 | 01:32 PM
EVO8LTW's Avatar
I have a serious potential buyer for my 03 Evo and who understandably would like a compression test. I have a compression gauge and have done a compression check before on a Mustang, so I understand the basic procedure.
What is the best way to disable fuel and spark on the Evo to do this test? I'd prefer not to have sparks arcing across the engine bay or injectors flooding out the motor.
Is there an injector fuse that I can just pull for the fuel?
On the spark, I'm less sure of what to do since the last car had a traditional coil wire that I could pull. The coil-on-plug set-up is a little puzzling.
Please advise.
Thanks.
Old Jul 22, 2004 | 09:59 PM
Nad1370's Avatar
Engine room fuse box. pull both engine fuses out. kills the power going to the ecu w/c disables the pump and ignition, but allows the starter to crank.
if you unplug the coil packs ( w/c youll need to anyways when comp. checking an evo ) will also disable spark.
Bexa20's Avatar
this is a good describtion on how to do it
http://www.evomoto.com/tech_info.php?techID=8
Old Jul 22, 2004 | 10:05 PM
Nad1370's Avatar
You might throw a CEL this way ^^
Liqquid
43
Nov 22, 2024 07:30 AM
IN IDLE
Nov 25, 2013 10:10 PM
m88lty
Mar 3, 2012 03:44 PM
NOMIEZVR4
Oct 9, 2010 05:24 PM
Brembo350z
11
Aug 1, 2005 05:23 PM
