Misfire
Old Nov 20, 2013 | 12:40 PM
IN IDLE's Avatar
Misfire
I have a bad misfire under load, have put new coils in, new plugs and gapped them to .020, sent injectors away to get flow tested and they came back good, compression test came back good, checked fuel regulator diaphram for leaks, it's fine, I'm running e85 and 600whp on a evo 4, any ideas would be much appreciated, thanks
Old Nov 20, 2013 | 05:30 PM
slowsrt4:('s Avatar
I have heard people saying things about e85 and the content changing with colder weather, but I'm really not sure
Old Nov 20, 2013 | 05:34 PM
PureDrivePerformance's Avatar
I'm assuming your boost is pretty high. What are your mods and boost level?
At that level I have most of my customers run .018" gap. What AFR are you running?
Old Nov 20, 2013 | 05:47 PM
IN IDLE's Avatar
Full boost is 31psi but it is missing on low boost as well which is 14.7psi and that makes 420whp, 2.0 litre garrett 35/40, ID2000 injectors, stock ignition
Old Nov 20, 2013 | 06:37 PM
evoforstevo's Avatar
ID2000 a gt35 and stock coils?? Get a COP set up
Old Nov 20, 2013 | 06:45 PM
701evo's Avatar
Did you change your gasstation recently?
Old Nov 20, 2013 | 06:54 PM
Can you post up a log when this is happening?
Old Nov 22, 2013 | 07:14 PM
IN IDLE's Avatar
Found the problem was a cam angle sensor
Old Nov 24, 2013 | 09:21 PM
blowngasket's Avatar
I've got the same issue under heavy load, changed plugs and it's better but still not right. Did u get a code?
Old Nov 25, 2013 | 10:10 PM
IN IDLE's Avatar
No I didn't but I have a aftermarket ecu and no engine light came on
cognizio
Outlander Sport
May 28, 2024 06:38 PM
mrhussain
24
Feb 16, 2017 08:01 AM
commbubba19
18
May 5, 2016 08:32 AM
tsitalon1
19
Feb 21, 2016 07:36 PM
Corrupter
Aug 29, 2015 07:40 AM
