High HP timing belt
Old Nov 22, 2013 | 10:08 PM
Darkn3s's Avatar
High HP timing belt
well im at around 650 hp and recently had my cam gear adjustment bolts back out on me and fell into the gears or something causing my gates belt to rip. Car only has less than 5k on it since build.
any particular timing belt is better to go with than others or another gates would be just fine?.. what do you HIGH hp evos run???
Old Nov 23, 2013 | 02:24 AM
droppinbottom's Avatar
Gates is what I run.
Old Nov 23, 2013 | 12:07 PM
TeachersEvo's Avatar
Use loctite on your cam gear bolts next time. It's not the belts fault foreign material got into it... a gates belt is probably just fine.
Old Nov 23, 2013 | 01:43 PM
superbovine's Avatar
Don't blame the belt because the engine wasn't assembled correctly to handle the power output
Old Nov 23, 2013 | 02:36 PM
420a-t's Avatar
Lol he wasnt blaming the belt....
ive known a bunch of high hp evos. Im running oem, others use oem or gates
Old Nov 25, 2013 | 05:38 AM
Fast_Freddie's Avatar
Veteran: Navy
I use the evo IX belt as it is kevlar reinforced as well... I have heard the gates belts are a tad waider than OEM can can rub the crank reluctor and cause a nasty whine... I want no part of that!
Old Nov 26, 2013 | 01:22 PM
Darkn3s's Avatar
the motor was assembled about 2 years ago and ran fine but a recent mount viberation issue caused most of my bolts to either back out or break loose. i tried to go after all the ones that i could, but i guess i missed those. I was considering the gates belt again but i just wanted input of those evos with high hp, to see what they ran or if they ever experienced any issues with a certain brand
wow learn to read
exactly, thanks man
Old Nov 26, 2013 | 01:23 PM
Darkn3s's Avatar
hmm ive heard that same thing about 9 belts but never heard the whine from my gates
MnchMnchV84Lnch
Jun 22, 2014 10:46 PM
xXANCHORMONXx
May 30, 2014 09:54 AM
tim85851
11
Dec 10, 2011 09:42 PM
project_skyline
Nov 10, 2011 09:56 AM
TTP Engineering
17
Jun 27, 2007 01:54 PM
