burp/hesitation/misfire?
Old Jul 27, 2004 | 09:41 PM
j3revo8's Avatar
hey..
i just got my car back from the body shop, had a dented door replaced. it took the shop over three weeks to finally get the door imported/painted and put on. while it was in the shop it was sitting on an empty tank of 91 gas.
so, i get it back fill up the tank and blow it out a little. later, i notice that while pulling the gears from a lower rpm up to 5k it gets a burst of deep tone farting sounds at the top of the shifts. if i keep the rpms high and run through the gears the sound/problem is not present.. i have had an ocassional backfire while changing gears in the past, but this is totally different.
i changed my plugs, check the wires, and check for oil in the plug wells. everything looks cool..im lost? could it be a coil pack? fuel filter?
i have 17k miles. 255 walbro pump, vishnu 91 flash, straight through exhaust. magnacore wires, colder ngk & denso irridium plugs. (swapped back to the ngks today) same problem..i can drive to work, i just cannot race. what to do?
Old Jul 28, 2004 | 08:09 AM
j3revo8's Avatar
bump
Old Jul 28, 2004 | 09:04 AM
The Reject's Avatar
Could be bad gas. Put in few gallons of race gas and see if if still does it. If so, problem found.
Old Jul 28, 2004 | 11:59 AM
plokivos's Avatar
gas would be my answer too, since it's been sitting around for 3 weeks with that same gas. GaS go bad in 2 weeks, if I remember correctly.
You should change your oil and gas as soon as you get your car back from having it sit too long.
Old Jul 28, 2004 | 12:47 PM
j3revo8's Avatar
thanks for the replies.
i will try a little race gas and change my oil. maybe buy a new set of plugs too.
who sells NGKBPR8ES online?
Old Jul 28, 2004 | 10:03 PM
j3revo8's Avatar
i tried the race gas 50/50 mix 91 & 100 0ctane. i then my plugs to new ngks, have yet to change my oil. i will tomorrow along with checking my stock BOV. i boost around 21psi. the sound and hesitation (like a stutter) occurs when i push the gears to around 45k RPM i dont go any further 'cause the stutter worsens. when i drive gradually through 2-4 gear it will climb to aorund 6k without any stutter?
fuel filter? bov? igniton coil? i dont reallty want to leave my car at mitsu. since most of them arent thorough..
**** man.
Old Jul 29, 2004 | 08:46 AM
j3revo8's Avatar
bump
any suggestions?
Old Jul 29, 2004 | 10:21 AM
Secret Chimp's Avatar
Changing your oil won't do anything for your problem.
Please do yourself and your wallet a favor. When you are trying to diagnose a problem by switching out parts, do it one part at a time. Change one parameter then take the car for a drive....repeat until the problem goes away.
SC~
Old Jul 29, 2004 | 02:16 PM
j3revo8's Avatar
i did change one item at a time. spark plugs first, then race gas, then oil ( i didnt think it would do anything either) any other suggestions? thx
Old Jul 29, 2004 | 02:45 PM
How did the car feel while running (unleaded hopefully) race gas? Did it feel any different?
Does this hesitation make your check engine light come on?
Old Jul 29, 2004 | 10:50 PM
j3revo8's Avatar
yes unleaded, 5 gal 30$ at tognottis.
no cel from the hesitation. good news though. i fixed it. after all the ****, it was the gaps were at .27 i changed to point .24 give are a take a half of a point. runs fun, i can boost again! now all i need is MR bov and the gruppe-s carbon heat shield.
next jan plan: exedy clutch (w/ss line) , adj. cam gears free reflash from shiv, and some dyno time. it feels good again to pull to redline. thanks for all your time.
Ude Lose
May 4, 2015 07:42 PM
jamesinger
Dec 11, 2012 10:51 PM
iggypooper
Aug 2, 2012 10:31 AM
deuce329
May 10, 2009 06:00 PM
Noize
29
May 20, 2005 12:00 AM
