Installed MR BOV, nice!
Originally Posted by EvilDylan
there was one guy who said he had the surging from the APS valve.
also $270?!?!? CRAP thats a lot.
i wish someone that had oe lived close to me so i could test it out for a couple days.
Originally Posted by Ted B
There is a new type coming out however that will 'blow' the vented air, but uses it to perform a certain job. This one will have its own terminology as well...
I have boost spiking issues (23.5psi) and apparent boost leak issues (17.6psi sustained) with the stock DV (engine is totally stock). I also have the stumbling and stalling issues.
Do you think the MR valve will help me?
Maybe someone that has a MR Bov and a wideband can let us know what their a/f ratio is before the stall to see if in fact the car is running too rich at low rpms.
Does anyone with an SAFC notice the same stalling problem?
i agree its a rich issue, I installed a injen intake and mine does the same thing and thats all i have done. Talked to a local tuner around here and he told me that it sounds like its rich in the lower rpm. That would be great if someone had a wideband so we could find out
Originally Posted by bamaevo
I do not have the MR BOV, but my car exhibits the same drop in idle and occasional stalling with the stock BOV. It usually happens when going through drive thru's or at intersections where you have to get rolling and then push in the clutch suddenly.
Point is, I believe it is something other than the MR valve causing this problem, maybe stock ECU being tuned so rich?
-M
Originally Posted by sleet
Does anyone have any problems with the MR BOV and a HKS RS intake? I've read a few stories of people having problems with the MR BOV and the HKS RS intake.
32k miles and counting
297whp@6500
262.3lb/tq@4000
This is on our mustang dyno w/ CA 91 pisst gas.
are you sure its the bov and not the turbo fluttering..
the only time it bucks is at slow speeds when ive got a few lbs of boost built and i let off and you can hear the valve flutter a little. No surge though, and the bucking is minimal.
one thing i did notice, spiking is a lot more prominent now. but if you are in a low gear accelerating hard, it only spikes for a spilt second, but say in 5th at 70 mph i floor it it will spike to 22-23 lbs (set at 20) and then go back to 20 lbs after a bit.
I just picked up my MR BOV about 30 minutes ago. I'm gonna install it tonight. By the looks of it a small child could almost do this install. My car is completely bone stock. Will I hear a "pssssshhhhh" even on the stock airbox/airfilter?
Clipse3GT
15
Jun 12, 2014 03:13 AM
Clipse3GT
18
Dec 16, 2009 02:48 PM
