valve train ticking.
Old Aug 18, 2004 | 10:39 AM
EVOnoir's Avatar
i just changed my oil to mobil 1 5w30 synthetic. and now i notice a loud ticking coming from the head when i rev the rpms up higher than idle. at idle it is silent. i only notice it when i give it gas or am driving. any ideas what this is?
Old Aug 18, 2004 | 10:43 AM
Stinkapuss's Avatar
Its normal valvetrain noise. Why are you using 5W 40 instead of 10W 40?
Old Aug 18, 2004 | 10:52 AM
EVOnoir's Avatar
as long as its nrmal... i use 5w30 not 5w40. i use 5 weight instead of the 10 beause its lighter on the valve train and can release a bit more power. im thinking of going back to the 10 because of my cams. should i do this?
Old Aug 18, 2004 | 11:32 AM
MalibuJack's Avatar
Its possible that the lighter weight oil is contributing to the ticking.. since its "Thinner" as long as you have oil pressure and don't suspect anything is otherwise wrong.. I do recommend going back to the 10w synthetic though.. The owners manual does say you can use 5w in extreme climates..
Old Aug 18, 2004 | 12:41 PM
Stinkapuss's Avatar
Oops, I meant 10w 30. I would stick with 10w.
Old Aug 18, 2004 | 03:56 PM
EVOnoir's Avatar
Old Aug 18, 2004 | 10:52 PM
naucrx's Avatar
I used 5W30 on my last oil change because the ghetto Mobil station I went to was out of 10W30 Mobil1. I also noticed my engine was ticking. I figured it was probably the oil. I only heard the ticking during idle though.
Old Aug 18, 2004 | 11:28 PM
4G63 Racer's Avatar
It could be Lifter lash, like on the 1g and 2g, cause it was loud when you would get it but you couldnt hear it when at idle. I evn heard a New eclipse afew days ago. But dont woory it normal for a DSM.
Hassan
103
Aug 5, 2023 11:37 AM
m3typer
Apr 5, 2011 11:35 PM
DFelton
26
Oct 20, 2010 10:28 PM
bstiffler582
Aug 1, 2010 08:24 PM
vietdragontekx
18
Jul 8, 2009 09:15 PM
