Greddy Profec B install help
Old Sep 1, 2004 | 08:59 AM
JaReDbOy's Avatar
Does anyone have any pics or info on installing the greddy profec b spec on the evo?
any help would be greatly appreciated!!
Old Sep 1, 2004 | 09:00 AM
SillySpheres's Avatar
Look in the How2 forums, there are a bunch of articles there. Alternatively, do a search and you will turn up a number of articles.
Old Sep 1, 2004 | 09:06 AM
jaapine's Avatar
May I suggest that you put a manual boost controller in instead. Reason being, I have seen may evo's with blown engines because of these electronic boost controllers going bad without even a sign. When they do, they tend to overboost and by the time you've noticed, you've blown your engine.
Old Sep 1, 2004 | 09:17 AM
PVD04's Avatar
Aside from the lack of space, the install is pretty easy. Just connect a hose from the pressure source on the turbo to the port marked NO, and connect a hose from the COM port to the wastegate. I found the easiest way to access it was to remove the intake pipe. You will also have to remove the stock hoses going from the Turbo to the wastegate, and then to the solenoid. I left the hose that goes from the solenoid to the intake pipe, and just capped off the other side of the solenoid. Other than that, you just need to get a pressure source for the control unit. I used a hose coming off the intake manifold for that. The wiring is all pretty straight forward aside from getting through the firewall. There is a How To on tuning the Profec that I found very helpful. Hope this helps.
JaReDbOy's Avatar
ive been searching and i cant find anything.. this is the greddy profec b spec - not the spec 2...
and um.. yikes.. well im going to be careful and watch my boost when i get on it,.. so it shouldnt be a problem...
can you link me to these articles cuz i cant find any??
thanks!
Old Sep 9, 2004 | 12:05 AM
ASTROEVO's Avatar
have you got your spec b installed yet?
Old Sep 9, 2004 | 04:07 AM
JaReDbOy's Avatar
yup we got it installed.
i like it alot! really easy to tune- just a twist of a knob!
Old Mar 23, 2006 | 03:36 PM
badstainless's Avatar
I actually just Installed my Profec b 2. I think I installed right but a couple questions.
1. Is it normal driveing while turbo isnt activated for it to show negitive PSI?
2. Can someone post pictures ( no descriptions please) of the exact location for the solinoid to be hooked up on COM and ON, ( sorry no one is really clear on where it should be )
3. im only hitting about 15psi now.. according to the meter on the profec. and suggestions? I am running 93 Octane.
Old Jul 1, 2006 | 09:04 PM
555R's Avatar
you need to turn your set up
try about 48-52%
Old Jul 2, 2006 | 09:40 AM
6-speed's Avatar
This is where I mounted my Profec B; right next to the Greddy TT.
https://www.evolutionm.net/forums/sh...d.php?t=206081
Just click on the bottom two picture links.
The install is not that difficult.
The instructions Greddy provided are pretty good.
Regarding the whole MBC versus EBC debate; they're many stories of both failing at one point or another.
The Profec B has a overboost safety feature that lowers your boost if you reach a maximum boost value you can set.
You can always keep an eye on your boost gauge too.
jay5565
Nov 29, 2015 04:14 AM
Stage2evo8
Jul 27, 2011 07:31 PM
SiLLyEVO
Aug 19, 2010 09:36 AM
Rocket
47
Dec 29, 2009 12:22 AM
max2evoix
Nov 6, 2007 03:48 PM
