CO/high altitude owners - boost question
Old Sep 5, 2004 | 05:02 PM
buddaboba's Avatar
I just installed my autometer phantom and it reads 16 psi up to redline all stock. Just wondering if this is normal for high altitude. Any info would be appreciated thanks.
Old Sep 5, 2004 | 05:18 PM
buddaboba's Avatar
Anyone?
Old Sep 5, 2004 | 05:25 PM
3240's Avatar
That's about right for altitude. I ran almost exactly the same boost when I was stock (I also live in CO). Install a boost control and crank it up to 19 or 20 psi.
Old Sep 5, 2004 | 05:29 PM
buddaboba's Avatar
You upped it to 19 psi with no supporting mods? I was planning on setting it to 18 which would be about 21 at sea-level I think. I'll probably do that after I get my TB exhaust and then dynoflash after that... Thanks for the reply!
Old Sep 5, 2004 | 07:54 PM
03venom's Avatar
I'm also at 5000+ feet. I'd love some input on a safe boost level with no supporting tuning at altitude. I was originally thinking 19 PSI, but now I'm starting to reconsiter... any input would be appreciated.
Old Sep 5, 2004 | 09:10 PM
3240's Avatar
I had an RNR 3" exhaust. I ran 19psi without any other supporting mods. Never had any problems. Good luck.
Old Sep 5, 2004 | 09:43 PM
chronohunter's Avatar
One my custom tuned Stage 1+ I run 1.6 bar (23.5psi) with no problems. I have run as much as 1.8 bar (26.5 psi) but Shiv turned it down on his last visit (). It made 338/360 on 91 with the 1.6 bar setting.
We need to run a couple of "extra" psi up here (and can safely) to get enough air in. I wonder if compressor maps are different up here? Can we run more boost without the same level of charge heating that would occure at sea level? It seems so because that boost level at sea level would knock...
Old Sep 5, 2004 | 11:01 PM
buddaboba's Avatar
Chrono do you have an upgraded fuel pump and/or Xede or flashed map? That much boost seems very high without some more fuel.
martoony
Aug 4, 2016 06:44 AM
dsmchiz
Oct 8, 2015 12:37 PM
dambikeracer
17
Nov 27, 2013 11:05 AM
Dynotech Tuning
Oct 12, 2012 10:55 PM
mtevoracer
Northwest Region
18
Aug 6, 2008 11:46 PM
