DV/BOV questions.
Old Sep 10, 2004 | 04:39 PM
Hatorade's Avatar
DV/BOV questions.
Ok. I'm a noob. I admit it. I know how BOV/DVs work, mechanically. I do not know how they are packaged and sold, however, so this is pretty much where I need help.
I'm interested in a recirculating valve. I'm also aware that many of these require a special flange to work, as they are universal kits. Does this flange go on the valve itself, so that it can be used directly on your car? Or does the flange only go on an upper IC pipe, which I'd have to purchase in addition to the valve? Or does it go both ways?
Are there direct replacements, that don't require modification to be put in place? If so, who makes them?
Any help clearing this stuff up for me would be greatly appreciated?
Old Sep 11, 2004 | 11:42 AM
Hatorade's Avatar
Bump.
Old Sep 11, 2004 | 11:47 AM
MitsuJoe's Avatar
The TurboXS H34 valve is a great replacement. If you get it from Lancershop it comes with everything you need. The sound and boost response/increase is also improved. Very good valve.
Old Sep 11, 2004 | 11:56 AM
lil'evil_evo's Avatar
Does this bov fit perfectly? Do you need any type of adapter?
Old Sep 11, 2004 | 12:42 PM
MitsuJoe's Avatar
It fits perfectly...the only thing I did was trim the rubber hose a little bit to make it so it was bunched up. This BOV is about an inch longer, but other than that it is perfect. I will snap a few pictures for you.
Joe
Old Sep 11, 2004 | 12:43 PM
Thanks. How does it sound compared to stock or the type-s if you have heard that one? Pictures would be cool thanks again
Old Sep 11, 2004 | 12:51 PM
MitsuJoe's Avatar
Here ya go...
Attached Thumbnails DV/BOV questions.-36879214469.jpg   DV/BOV questions.-36879246597.jpg   DV/BOV questions.-36879278213.jpg
Old Sep 11, 2004 | 12:52 PM
MitsuJoe's Avatar
I do happen to be using a dejontool intake pipe which I wasn't using when I first got this BOV. It will fit great with the stock intake pipe.
KRod223
Aug 12, 2021 12:08 PM
Chris@nolimitmotors
447
Dec 26, 2018 04:09 PM
me612
11
Feb 1, 2006 04:01 AM
JSYEVO
Oct 28, 2005 07:59 PM
Kwman
Jul 3, 2004 12:05 AM
