TRANSMISSION, TRANFERCASE, & REAR DIFF. FLUIDS
Old Sep 11, 2004 | 06:51 PM
x7eVoLuTiOn7x's Avatar
Transmission, Tranfercase, & Rear Diff. Fluids
ok guys, from what I read on this site seems like:
TRANSMISSION = redline MT90, BG synchroshift or Penzoil synchromesh
TRANSFER CASE = redline heavy shockproof or mobil 1 75W90
REAR DIFFERENTIAL = redline or mobile 1 75w90
* You can use the same fluids for the transfer case & rear differential = 75w90*
I got an evo7 with ACD/AYC........would these fluids be OK for my car?
Would it be recommended to change ALL these 3 fluids every year? I was told you only need to change them every 40,000 miles?
This is my weekend car so I dont use it that much. Maybe about 4,000 or less miles a yr. I've got around 11,500 miles on it. havent chnged the fluids yet.
HOPE THIS THREAD WOULD END THE CONFUSION ON W/C FLUID GOES TO WHERE
Old Sep 11, 2004 | 06:59 PM
JDM_FeTiSh's Avatar
From: [6][5][0]san mateo, California..."rEpN dA YaY aReA!!"
ya you use the same on all three. 75w 90 .. i'm pretty sure since thats what we use at our shop for all the mitsu cars. .. daym you need to drive more haha jus messn. not sure when you have to change your gear oil. but 40,000 sounds knda high. we usualy do it lke 30k but its all on you like how you drive it.
Old Sep 11, 2004 | 07:30 PM
evo81's Avatar
you don't use the same fluid on all three areas
Old Sep 12, 2004 | 02:39 PM
Crazy4Cars's Avatar
I tried them all on my Evo7, this was and is the best combo found.
Tranny: BG Syncroshift
Transfer: Royal Purple 75/90
Rear Diff: Royal Purple 75/90
Old Sep 12, 2004 | 03:24 PM
Karash's Avatar
I just put in BG Syncroshift in the Transmission, and Redline 75w-90 in the Transfer Case and Rear Diff.
Old Sep 12, 2004 | 04:07 PM
Novtec1's Avatar
Veteran: Army
bg syncoshift in tranny....redline heavy shockproof in tranfer case and rear diff.... only been in for 2 days but it feels pretty good.
Old Sep 12, 2004 | 06:48 PM
Mark T's Avatar
Is the Royal Purple called "max gear"?
Old Sep 12, 2004 | 07:05 PM
taylor's Avatar
I would use sae 90 in the transfer case. This is exactly what mitsu recommends, and a signifcant amount of people have killed the transfer case using 75/90, just my 2 cents. I personally will be using Royal purple max gear SAE 90 gl5 in both the t-case and rear diff. and a blend of Redline MTL and MT-90 in the trans.
Old Oct 7, 2004 | 09:34 AM
Gracing2000's Avatar
I have a winding sound coming from my TC, will this heavy duty thicker fluid lessen the wind or make it worse??
FlipSquad
Jul 24, 2017 03:21 PM
evox7
49
Jul 13, 2008 10:50 PM
scherejs
26
Mar 8, 2008 11:23 AM
grips03
Jul 13, 2003 06:26 PM
