Defi Control Unit II Install HELP!
Old Oct 23, 2004 | 09:50 AM
crusin_lancer's Avatar
I'm wiring the control unit and I have the center console apart, but which wiring goes where? If you could just tell me what color goes to what color that would be awesome. I tried evomoto's install, but it seems no longer available. Someone please help I would like to put my car back together.
Old Oct 23, 2004 | 10:28 AM
BUMP! anyone? It should be the same for all the control units and I know theres tons of guys out there. Please someone help out.
Old Oct 23, 2004 | 10:44 AM
LateSleeper's Avatar
Do you have an aftermarket radio installed? If you do, you can get away with an easy install. I connected my controller to the aftermarket radio harness. The constant power, switch power, and dimmer connections were labeled well. I'm not sure how the other guys have them hooked up.
Old Oct 23, 2004 | 10:52 AM
Cool I'll check it out. You know what colors? I know the illumination wasn't connected.
Old Oct 23, 2004 | 12:44 PM
Bump! Anyone?!?!
Old Oct 23, 2004 | 06:31 PM
nm I figured it out. I spliced into the yellow wire on the aftermarket harness. Constant power to keep records and memory for the defi control unit if anyone needs to know.
Old Dec 14, 2004 | 07:47 PM
djmikeymike's Avatar
what did you splice the white wire to
Old Dec 15, 2004 | 08:59 AM
White is ilumination right? I think I use the green wire with the white stripe going to the cig lighter. Then I used the brown wire for AC power and used the radio harness for constant power. The ground to a suitable spot.
Old Dec 16, 2004 | 03:23 PM
'ringmeister's Avatar
-thats what i used for illumination. i grounded to black wire off the cig lighter, and red wire off the cig for switched power. for constant power i tapped into the red w/ black strip off the ecu harness. only problem i have is that the gauge light doesn't dim. did you experience the same?
Old Dec 16, 2004 | 03:38 PM
yea I did... Its wierd because the cig lighter dims too. Is there a different wire that dims? I did exactly what you did but my constant power I used the radio harness.
foxbear2277
Aug 16, 2012 05:09 PM
AndyCT9W
15
May 8, 2012 07:46 PM
DangerousDan
Aug 10, 2007 07:00 PM
johnsrt4
11
Oct 20, 2006 11:50 PM
rocketscience
Feb 12, 2004 03:13 PM
