Opinions onf my Dyno
Okay guys heres my Dyno sheet.. what do you guys think? I have an intake, exhaust 3' w/ downpipe and no cat... first run was with what i was driving with which was map 2 on the UTEC with 22psi of boost and final "test" run was with the UTEC tuned with map 2 set for 22psi. i was the second evo ever on the dyno.. their first was a stock evo and it pulled 220hp... at another dyno in atlanta a stock evo pulled 180hp. let me know what ya think!
P.S. Yes I have many more future plans for my '04.. this is just the beginning
What kind of gas? IMHO, 270whp is a little low considering your mods. You should be right near 300whp. Did you use a UTEC map off the internet, or did you get a custom tune?
it was 93 octane and I used the base map that came built into the UTEC itself for 22psi of boost... tweaked it alittle in the fuel map area to remove some small knock that i had
Originally Posted by umiami80
Its a Mustang Dyno, he may be over 300WHP on a Dyno Jet, so that is good.
