Head unit install
Old Dec 19, 2004 | 06:01 PM
plokivos's Avatar
Head unit install
quick question regarding installing the head unit.
What do I need to get this installed?
part number and place to get em would be great.
i have the old JVC unit that I wanna put it in my car.
Thanks.
Old Dec 19, 2004 | 06:05 PM
HoLeeRay's Avatar
You can take the mounting brackets right off of the stock HU. If you don't feel like splicing wires, some wiring harnesses would be keen. A philips head screwdriver would help, too.
tke_413's Avatar
Go to Best Buy and tell they you need a radio wiring harness for your car...follow the directions that came with your head unit to find out what wires go together...plug and play.
Old Dec 19, 2004 | 06:11 PM
plokivos's Avatar
that's it, best buy?
alright, i'll go tomorrow.
You could use the stock headunit mount?
that means, I probably only need that harness.
Old Dec 19, 2004 | 06:22 PM
tke_413's Avatar
That's all you should need, Mitsu makes it really easy to put different headunits in.
Old Dec 19, 2004 | 07:18 PM
plokivos's Avatar
sweet, i'll let you know tomorrow.
Old Dec 19, 2004 | 07:30 PM
Evoisdream's Avatar
Nice thats good news i was thinking of doing the same thing here soon 2!
evoisdream
Old Dec 19, 2004 | 07:45 PM
plokivos's Avatar
i wonder if theres "how to" on this
i'll go check
Old Dec 19, 2004 | 07:50 PM
HoLeeRay's Avatar
once you get the panel off, you'll see that it's really really easy. pull off the AC control dials, unscrew the two screws, pull off the panel, unscrew the 4 screws holding in the stock radio, unscrew the mounting brackets on the sides of the radio, screw on the mounting brackets onto new radio, use the wiring harnesses, ground it, screw everything into place.
the radio i put in this car was my first experience installing anything to do with a radio/electronics/stereo in a car and i did it in under 30 minutes.
Old Dec 19, 2004 | 07:56 PM
cuprsnel's Avatar
I think I got my harness at CircuitCity. They had a mitsu to universal and a universal to alpine. Then just plug it in.
HoLeeRay's Avatar
circuit city is where i went
Old Dec 19, 2004 | 08:09 PM
wingnut's Avatar
Where did you guys ground your HU's? I grounded mine to the mounting screws but I think I can do better. Is there a good spot on the firewall?
Old Dec 19, 2004 | 08:12 PM
HoLeeRay's Avatar
i grounded mine on the mounting screws, there's a better place by the firewall, but i didn't have the tools to undo the screws there.
