Oem Fog Lamps For Evo 7 Gsr
ATTENTION ALL EVO 7 GSR OWNERS
Do anyone of you know what type of bulb for the foglamps the Evo 7 GSR is using? I know that the High/Low beams are HB3/HB4. How about for the OEM fog lamps???
evocrazy: Btw, did your GSR came with HIDs as standard equipment or an option from
Since ours (RS2) didn't come with the foglamps and the HIDs, (but has a headlight beam leveller) I'm thinking of upgrading them to the GSR type headlights (losing the leveller function for the foglamps since there is only 1 place for the leveller or fog lamps switch). I'm assuming the front foglamps switch is beside the rear fogs switch. Am i right?
Thanks in advance for the info.
? Since ours (RS2) didn't come with the foglamps and the HIDs, (but has a headlight beam leveller) I'm thinking of upgrading them to the GSR type headlights (losing the leveller function for the foglamps since there is only 1 place for the leveller or fog lamps switch). I'm assuming the front foglamps switch is beside the rear fogs switch. Am i right?
Yarima
11
Aug 7, 2009 06:25 AM
