All Part Number Request Go Here
Old Jun 15, 2007 | 08:26 AM
  #1861
Spins4's Avatar
Originally Posted by dwai
I have the camshaft position sensor - MD327107 - but I need the entire assembly that bolts to the head, are there part numbers for the rest of the assembly available?
Thank you
The piece that the sensor goes into is MD344722, the cover for it is MD329502, the gaskets to the cover is MD329503, the bolts are MF140025 & MF140204 .
Old Jun 15, 2007 | 08:27 AM
  #1862
evleb's Avatar
hi,
do you have the us 9 headlights in stocks?
how much?
thanks
Old Jun 15, 2007 | 10:10 AM
  #1863
JMB8606's Avatar
Originally Posted by Spins4
Those are correct. Might want to replace your downpipe gasket, but other than that, your good!
You are the man thanks for you help
Old Jun 15, 2007 | 10:36 AM
  #1864
Spins4's Avatar
Originally Posted by evleb
hi,
how much?
thanks
Def not. As for a price, looking at $1038 each
Old Jun 15, 2007 | 10:37 AM
  #1865
Spins4's Avatar
Anytime
Old Jun 15, 2007 | 11:41 AM
  #1866
hkfeet's Avatar
need part # for the 2 17mm nuts that secures the bolts from strut braket to knuckle. thanks for the front part numbers btw
Old Jun 15, 2007 | 01:58 PM
  #1867
HxllxMan's Avatar
Hi again,
still looking for the spindle ( not sure what's the right word in english )
Part where you mount the caliper, brake rotor, rim, ect... Need the Rear left and right.
Old Jun 16, 2007 | 10:19 AM
  #1868
whitersevo's Avatar
I need the little white/clear pop on clips on the front bumper it self, they are located 1 on each side right below the headlight... The ones where you have to push the bumper down a bit to pop them out.. broke one off and now the bumper does sit right lol...
Old Jun 18, 2007 | 06:26 AM
  #1869
scherejs's Avatar
lower dash panel request
Does anyone have the part # for this interior piece outlined in red. 2003 VIII
thanks
Old Jun 18, 2007 | 07:44 AM
  #1870
Spins4's Avatar
Fronts: MD090875
Rears: MU431503
Old Jun 18, 2007 | 07:46 AM
  #1871
Spins4's Avatar
Originally Posted by HxllxMan
Hi again,
Left: MR554827
Right: MR554828
And in case you need the hub assemblies, becuase they are not included, MR403968 (x2).
Old Jun 18, 2007 | 07:50 AM
  #1872
Spins4's Avatar
These the ones that "attach" to the fender? If so, would that be the outer most one, or the inner? Been a while since I have had my bumper off..
Old Jun 18, 2007 | 07:51 AM
  #1873
Spins4's Avatar
thanks
MR633551
Old Jun 18, 2007 | 08:50 AM
  #1874
MadCrix's Avatar
can i get the part number for the bulb that lights up the inter cooler spray switch?
Old Jun 18, 2007 | 09:06 AM
  #1875
Spins4's Avatar
Actually you can not get the bulb seperate.
