All Part Number Request Go Here
Old Oct 11, 2007 | 05:19 AM
  #2116
EvoTech's Avatar
Originally Posted by MadCrix
hey anyone got the part number for the 4th gear syncro?
either up shifting or down shifting results in grating at high rpms..
and any other parts and part numbers required with the 4th gear syncro when i replace it
thanks
Get a hold of the TSB for he 5th gear syncro grind and it will list all the parts that you need. It lists all the syncro's and a few other parts that are needed.
Old Oct 12, 2007 | 08:25 AM
  #2117
ff-evo's Avatar
I have search for this everywhere before asking this question. I need the actual part number for the oil drain/return tube off of the turbo. I have the gasket numbers already I just need the actual tube number. Kinda funny, should have disconnected the battery to unbolt the downpipe. Because I arced across the starter and popped a hole in the oil return/drain tube. I'm retarded.......
Old Oct 12, 2007 | 08:57 AM
  #2118
RussellM's Avatar
Plat Vendor
Here ya go!
http://www.mitsubishiparts.net/cart/...=11&submit.y=3
Old Oct 12, 2007 | 02:13 PM
  #2119
thatsMR2u's Avatar
i got one never used if u need it- ill sell it cheaper than the dealerships- PM me
Old Oct 14, 2007 | 07:46 PM
  #2120
6-speed's Avatar
Searched but couldn't find the part number for the transfer case drain plug washer.
Anybody know the part #?
Thanks in advance.
Old Oct 15, 2007 | 08:12 AM
  #2121
WalpoleMitsu's Avatar
part number is mn130495 and i got them instock for 3.17 plus shippin.
Thanks in advance.
Old Oct 15, 2007 | 09:22 AM
  #2122
6-speed's Avatar
Thanks.
You have a PM.
Old Oct 15, 2007 | 10:57 AM
  #2123
MadCrix's Avatar
hi i am looking for the part labelled 1(i need the right side) below and the clip to hold it in place.. thanks
Old Oct 15, 2007 | 11:00 AM
  #2124
i cant make out any of the numbers. do you kno what it is called?
Old Oct 15, 2007 | 11:48 AM
  #2125
MadCrix's Avatar
changed the pic sorry
its called a console side cover
Old Oct 15, 2007 | 12:55 PM
  #2126
alright now i can see it. Your lookin at mr623873 and i can order it for you for 15.55 plus shippin and it comes with two clips to put it on.
Old Oct 19, 2007 | 07:31 PM
  #2127
avs's Avatar
avs
I need part no. for this metal plate that's on the lower front bumper, behind the air dam.
Old Oct 22, 2007 | 10:37 AM
  #2128
WarmPepsi's Avatar
Front Bumper, Electric blue. 2006 IX.
Old Oct 22, 2007 | 10:27 PM
  #2129
budlong's Avatar
the smoked plastic lense that the clock sits behind, not the clock itself, just the lense/cover.
evo IX
Old Oct 23, 2007 | 08:00 AM
  #2130
Greg K's Avatar
Rear wheel bearing assy.
